Problem with JSS
  • December 20, 2011
  • 10 views
Hello, i'm new here and currently running the trial of Casper, but
right now I'm bashing my head against a wall out of frustration. What
I'm seeing is that inventory doesn't seem to update properly, i'm
using 8.31.
Here's what I get when running jamf recon on a machine via ssh.
hjl$ sudo jamf recon -realname "Jurgen Linde" -displayJSSTraffic
Retrieving Inventory Preferences from https://jssname:8443//... Uploaded: 640 bytes Downloaded: 1 KB Total Traffic: 2 KB
Locating Hard Drive Information...
Locating Hardware Information (Mac OS X 10.7.2)...
Locating Applications...
Locating Fonts...
Executing Unix Applications...
Locating Receipts...
Gathering Application Usage Information...
Finding Extension Attributes...
Submitting data to https://jssname:8443//... Uploaded: 147 KB Downloaded: 0 bytes Total Traffic: 147 KB
There was an error submitting the computer to the JSS. Here is what
the JSS reported back:
<request>650</request><uploaded>150845</uploaded><downloaded>0</downloaded>
Running this command...
Password:
https://02cpt-xodm01.za.ds.naspers.com:8443//...
Locating Fonts...
Submitting data to https://02cpt-xodm01.za.ds.naspers.com:8443//...
So when adding the DisplayJSSTraffic flag, I can see that there's an
obvious problem...when the flag is not there, it appears as if it runs
fine, but obviously it doesn't. What I also see in the particular
computer's log on the JSS is that zero entry appears on the inventory
log, I can run this command manually as many times as I want, it just
doesn't show up, as if it never ran an inventory.
It really doesn't make sense at all because when I run Recon.app it
does work 100%.
The fact that the recon command causes all scripts to fail that
interact with it. Just driving me a little insane right now ;)
Any ideas?! I'm using the default self-signed cert btw.
  • December 20, 2011
Jurgen,
Try running:
jamf recon -saveFormTo /tmp/
There will now be a file in /tmp/ called [machinename].reconForm. Now you can look at the data that is trying to be submitted back. You may wish to reformat the data, so try:
cat mac118.reconForm | tr "&" " "
My experience so far with 'There was an error submitting the computer to the JSS. Here is what the JSS reported back:' has been to do with characters that Casper can't handle.
For example, the '%' symbol causes errors, from incorrect reporting to the above failed to submit. The & symbol in Application names will cause the JSS to fail to submit. You'll notice that from the above cat, a name with a & in it will show as:
applicationPath=/Applications/Server/Casper Suite 8.3/Documentation %26 Resources/Resource Kit/All Tools/
This conversion of & to %26 then causes the failed submission. In the past, plugins with the a % in their name caused incorrect reporting of the version numbers of plugins, eg.
pluginPath=/Applications/Adobe Photoshop CS3/Plug-Ins/Displacement Maps/Random strokes 25%
So I'd start with doing the reconForm, and then cat the file and grep for %
cat mac118.reconForm | tr "&" " " | grep "%"
Find any, then rename them and try again.
Sean
  • December 20, 2011
My word, Sean, you're absolutely correct. During my testing I enabled
On Tue, Dec 20, 2011 at 1:34 PM, Sean Holden <Sean.Holden at framestore.com> wrote:
the function to add fonts as part of the inventory collection. I didnt
find any % signs in my report, but I do know there are some chinese
character fonts by default installed on OS X Lion, guess 10.6 as well,
but after I disabled it to collect fonts, the problem vanished.
How come this is still a problem though? One would think JAMF would
have fixed such a silly problem long time ago? It's surely not that
hard. Question still remain though... why can Recon.app submit it
properly, but not the command in terminal?
