Problems enrolling Yosemite
  • November 12, 2014
  • 14 views
We are having issues enrolling Yosemite. It is a clean installation as if the computer was out of the box. So far none of these options have worked: -Local Enrollment via Recon app -QuickAdd Package made through Recon
-User-Initiated Enrollment
With Mavericks, it works fine.
JSS and Casper Suite have just been upgraded to the latest version as well.
adhuston
  • November 13, 2014
Any chance you're using a custom path when inventorying Applications? I had the same issue, see:
https://jamfnation.jamfsoftware.com/discussion.html?id=12205
  • November 13, 2014
Are you using a Thunderbolt to Ethernet Adapter in the Yosemite Mac you're trying to enroll? There is a know issue in the Casper Release Notes:
[D-006627] When restarting a computer that has been imaged using Casper Imaging, the computer fails to enroll if attempting to connect to the JSS via an Apple Thunderbolt to Ethernet Adapter.
As far as I know, it was documented for the first time in 9.4 and persists on 9.5 9.51 9.52 9.53 9.6 and 9.61.
