problems in distributing packages
  • September 6, 2012
  • 5 replies
  • 30 views
Sending Wake On LAN command...
Opening SSH Connection to 10.226.56.109...
Authenticating...
Successfully authenticated.
Verifying Computer's Identity...
The MAC Address has been verified.
Checking Operating System Version...
Running Mac OS X 10.7.4 (11E2617)
Verifying /usr/sbin/jamf...
/usr/sbin/jamf is current (8.52)
Verifying /usr/sbin/jamfvnc...
/usr/sbin/jamfvnc does not exist.
Verifying /Library/Preferences/com.jamfsoftware.jamf.plist...
Preparing Policy...
Executing Policy 2012-09-06 at 5:56 PM | andres.triana2 | 1 Computer...
Downloading BOM for Computrace McCann LatAm 2.pkg...
This Apple Package did not have a valid index.bom file. Assuming it is a flat file package.
Downloading http://10.226.56.36:80/CasperShare/Packages//Computrace McCann LatAm 2.pkg...
Error: The package could not be found on the server.
Submitting log to https://10.226.56.36:8443//...
Finished.
Best answer by jarednichols
Don't suppose your web server is IIS...
  • September 7, 2012
Forum|alt.badge.img+21
  • September 7, 2012
  • September 7, 2012
Nothing like IIS throwing up stupid 404 errors when you're missing a MIME type. Stupid hunk of crap...
  • September 11, 2012
hi jarednichols es en lion server 10.7.4
Having the same problem on a 10.6.8 server. Rebooted the server and it went away but it tends to recur. Haven't been able to find a cause. Happens with both folder and flat packages.
