Problems with Enrollment and the Execution Frequency Once per Computer
  • June 10, 2020
  • 10 views
I have a problem with the enrollment and the related policies. I have created a policy that will be carried out after the enrollment. The trigger is enrollment complete and the execution frequency was once per computer. That also worked one time for the computer. If I re-enroll this computer, this policy will no longer run. How can I get it back to running this policy again? I have now changed the policy to Ongoing. But the computer will not do it again.
1 reply
sdagley
  • June 10, 2020
@saltevog If you're not removing a computer from Jamf Pro before re-enrolling it you can change the Re-enrollment behavior for your JSS so your run once policy will run again. In Settings->Global Management->Re-enrollment enable the option "Clear policy logs on computers" to do that.
