Hello all,
This is my first post on here, so I hope its relatively clear, apologies if it isn't ;-). So I am trying to deploy a installation package containing Adobe Design Standard CS6 using a Casper (Version 8.73) policy to over 50 mac computers all ranging from OSX 10.6.5 to 10.9.5. Here is what I've done so far;
I have created a deployment package using Adobe Application Manager Enterprise edition 6.2.112.0 and moved this into Casper Admin. I have also followed the Casper recommendations for the creation of the package itself.
From Casper Admin I created and configured a policy using the JSS browser > Management > Policies. I set the policy execution frequency to run "once per computer", the trigger as "any" and ran a test on these versions: 10.6.5 10.7.5, 10.8.5 and 10.9.5
The only one that actually installed was 10.8.5, the rest threw up errors. To be more specific, when I selected "view status" after the install and selected "view log" it had this exact message:
installer: The install failed (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.)
Installation failed. The installer reported: installer: Package name is Adobe CS6 Design Standard
installer: Installing at base path /
What makes this slightly confusing is that I have tried them all individually since and they have all installed. The only thing I changed on the policy was trigger to "startup" and execution frequency to "ongoing" and looking at the individual logs after one or two failed attempts it finally installs on each OSX version. Bearing in mind I am going to be rolling this out on more than 50 computers, it would be good to know and rectify whatever is making these installations fail. I have tried troubleshooting but to no avail. I'd really appreciate any help you could give.
Many thanks.
Chris
