Profiles constantly re-installing
  • October 14, 2019
  • 26 views
I re-enrolled my device in our cloud instance, and whenever the computer performs a recurring check-in (or I run a jamf policy command), all of my MDM profiles are pushed to the device. The scope doesn't change, so there shouldn't be any need to have the profiles added or removed. I never saw this issue with out on-prem JSS. Has anyone else seen this? I used the ReEnroller provided by Jamf which removed all of the old profiles.
  • July 9, 2020
@PhillyPhoto I'm seeing this too. Did you ever find a resolution?
  • July 10, 2020
@ooshnoo not really, I haven't built any devices in a while and I'm not sure if it went away with a newer version of the JSS or not.
