Proxy Setting Smart Group?
  • December 19, 2012
  • 4 replies
  • 17 views
Is there a way to create a smart group based on if the user has Automatic Proxy Configuration set?
Best answer by justinworkman
I just tested this as an extension attribute:
proxystatus=$(cat /Library/Preferences/SystemConfiguration/preferences.plist | grep -A 1 Proxy | grep -o 1)
echo "<result>$proxystatus</result>"
If you make a Smart Group based on proxystatus is 1, it should do what you're needing.
Forum|alt.badge.img+19
  • December 19, 2012
you'd first need to create an extension attribute that returns the status of that proxy setting. then, you could create your smart group based on the extension attribute.
  • December 20, 2012
  • December 20, 2012
  • March 5, 2013
I can't get this to work on mountain lion, any recommendation?
