Pulling data from the JSS for asset management?
  • September 18, 2014
  • 28 replies
  • 120 views
Hi guys,
I am looking to create a new asset management system through Sharepoint (or something similar if you could recommend), listing all of the devices in our office. Ideally it will pull data from the JSS as that would always have the most up-to-date information on each device.
Anyone aware of any way I could do this, using a script or something similar?
Input would be much appreciated.
Thanks very much.
nothing like re-inventing the wheel ;) Have you looked at what is available via the JSS API?
Sorry, to be more specific, it's so we can keep track of what is out on loan, what has been broken etc
Ahhh ok gotcha. I'd look at what you can pull via the API, and see if you can set up some kind of sync/import of new devices that way new device gets added to casper the sync/import happens and adds it to your AM system.
Here is what you are going to need:
1) Setup some kind of cron job to run this script.
jssUser=Username
jssPass=Password
jssHost=https://chscasper.pretendCompany.com:8443/
Computers=$( /usr/bin/curl --request Get --user ${jssUser}:${jssPass} ${jssHost}JSSResource/computers 2> /dev/null )
ComputerID=($Computers)
#Convert Computers to an array
read -a ComputerID <<<$Computers
for ID in "${ComputerID[@]"; do
   #some code you want to do.  Like export to csv file, or other to each line item.
  cat $ID >> computerlist.csv
done
Hope this helps.
donmontalvo
Forum|alt.badge.img+36
I'm not exactly sure how but I know our webmaster designed added a page onto our inventory system that pulls live data direct from the JSS database for iPads/Macs, Models, how many we have in each building etc. That way we don't have to rely on the API.
If you were looking to do something like that I can could get some more information from him on how he did it.
i use Web Helpdesk by Solarwinds (http://www.webhelpdesk.com/), which has the ability to connect directly to the JSS to pull asset/inventory information. hope this helps.
wally
  • September 19, 2014
@peineke Yes please. That's exactly what I'm looking for. Thank you.
donmontalvo
We had an asset manager who provided an Excel spreadsheet that ran queries on launch. Took a few minutes to launch, but MAN it was awesome to have all that detail at your fingertips. :)
  • September 25, 2014
Any other ideas?
donmontalvo
  • September 28, 2014
Why not post in the IRC? I'm sure mister Allister Banks would be happy to provide some helpful advice. :)
external image link
http://www.afp548.com/2006/11/22/join-the-afp548-irc-channel/
Forum|alt.badge.img+23
It would be possible to do this all in the JSS using an Extension Attribute populated by a drop down menu. I might call it "Disposition" with values like "In Production", "Lost", "Stolen", "Out For Repair", "On Loan" (perhaps attaching a scan of a signed loan agreement to the computer record in the last case).
I hope this is helpful.
  • September 30, 2014
We've done what @milesleacy suggested, plus an additional couple of EAs where we document the date and results of the last run of Apple Service Diagnostic along with a summary of physical condition. We end up with a record that clearly indicates the location, disposition and hardware condition of the system. We just dump this out to a csv if we have an internal need or incoming request from Accounting or any other group that might need an idea of our inventory. Hope that helps!
  • October 14, 2014
Hey All- Check out https://www.oomnitza.com/
I work there so I'm biased, but it's great for asset tracking and pulls from Casper.
Forum|alt.badge.img+19
  • October 15, 2014
You could add some extension attribute fields - eg. Hardware status, to display whether an item is stored, disposed (so it can be removed from inventory), issued, repairs, etc...
Then query the JSS API to obtain a list of computers in current inventory, use these results to query your external asset system/records, then use the JSS API to write back these fields. You could use a cron job to schedule this periodically and have the data automatically update from the external source. (Or go the other direction pull data from the JSS for the external source).
Shameless plug - I'm going to be presenting on this at an upcoming NYC user group meetup with code examples.
bpavlov
  • October 15, 2014
Lisa,
Is this a public group meetup? Would love to attend if so. Are you allowed to share the group meetup info? Would private message you, but still new to the forums and can't quite find that message button (assuming it even exists).
  • October 15, 2014
Mark organizes the NYC meet ups - I believe he will be posting the upcoming eventbrite invitations to the forums soon.
  • October 15, 2014
@lisacherie Mark's wife is expecting mid-November so I offered to assist coordinating and he mentioned someone else might be as well. @bpavlov I'll keep you posted.
  • October 15, 2014
  • November 12, 2014
Hi Guys- I work at Oomnitza. We built a connector between Jamf and Oomnitza (Asset Management)
https://github.com/Oomnitza/oomnitza-casper-sync
https://wiki.oomnitza.com/wiki/Main_Page
  • February 5, 2016
If you are looking at oomnitza, make sure you press hard to get a trial. I have some serious buyers remorse right now.
I have been working with our Rep... but I don't have enough time in my work week to work out all the Oomnitza issues we have been having.
  • February 23, 2016
Hey Andrew, can you share what issues you've had? I'm looking for an ITAM system.
Also, I'm a little concerned by the fact that Oomnitza doesn't support their own plug-in in the Atlassian Jira marketplace.
  • February 24, 2016
Hello Syncron. Good timing. I just logged into my Oomnitza account, and found that the system automatically imported a bunch of BYOD iPads that we don't own... Even though I have it in writing that they are not to import any mobile devices from the JSS. The phrase "surprise" and "inventory" do not mix well in my book.
What really chaps me right now is I have no one to talk to about this issue. Their listed phone number goes to voicemail with the promise of someone getting back to me in 24 hours. Probably for the best since I am pretty P.O.'d right now. I emailed our rep, but he is on California time, so I guess I will just wait around until he gets back to me.
Additionally, the GUI is clunky. The idea that you can't set a custom inventory view on a per user basis drives me insane. The language and interface in other parts of the GUI is sloppy. I can come up with a few different examples where the interface is confusing.
The Mobile app is garbage. Lets say you want to use the mobile app to assign a username to a asset. There is no search box for the user. You literally have to scroll through every AD account until you find the person you are looking for. We have over 3000 AD accounts... As you can imagine, that is a lot of scrolling.
Setup was pretty slow. A simple task like setting up our LDAP connection took 4 business days.
I keep telling myself that once we start using the workflow features, this product will be worth it. I'm trying to stay optimistic, but my patience is wearing thing. Ultimately I feel like our initial salesperson over promised and under delivered. If the service were less expensive, I wouldn't be complaining.
  • April 15, 2016
@andrew I've used a number of different asset management solutions, and although Oomnitza isn't magic, they are the most responsive I've found.
You can find my attempts to solve other asset management tools on my github... but that was after literally months of making the same requests. I have been working on-and-off with Oomnitza for more than a year, and they've been quite responsive, even when obviously haggered.
My feeling is that the asset management space has a lot of "hey this isn't polished to a level commensurate with my dreams!" but no one actually making that tool. Oomnitza plugs into the services I have enjoyed using: JIRA, Zendesk, JSS, and the like.
They're not a godsend, but they get the job done in the best way I've found, to date. And they're not trying to shoe-horn in my asset manager into a service desk ticketing solution. To paraphrase Gruber, "know the difference between being someone's customer and being their product." I'd rather pay a company to get them to do what I want (Oomnitza), than coerce them to maybe get to my wishlist, 'whenever they have time for it' (SAManage).
  • April 15, 2016
Hi, you said: "Sorry, to be more specific, it's so we can keep track of what is out on loan, what has been broken etc"
Well I did that with our casper system - I added an extension attribute, OpStat (short of 'Operational Status') that was populated via menu, and populated the menu with various options.
"Live", "Gone for Repair", "Damaged", "Gone to Show", "Decommissioned", "Stolen", etc..
(whatever states you want to use..)
Then you can simply use Casper.. Without needed to mess about with anything else..
