Push Wireless network Certificate and set EAP and x.509 Basic Policy to Always Trust
  • Jul 17, 2024 6:42 PM UTC
  • 5 replies
  • 252 views
Forum|alt.badge.img+15
I'm trying to push Certificate and set EAP and x.509 Basic Policy to Always Trust. I tried installing the cert and then modifying the settings, exporting the cert, then add it to a config profile but when deploying it, the settings never stick.
I also tried to push it via policy with PostInstall script:
security add-trusted-cert -d -r trustRoot -k "/Library/Keychains/System.keychain" "/private/tmp/certs/certname.cer" srm "/private/tmp/certs/certname.cer"
Also tried : security add-trusted-cert -d -r trustAsRoot -k "/Library/Keychains/System.keychain" "/private/tmp/certs/certname.cer" srm "/private/tmp/certs/certname.cer"
All with no luck. Has anyone tried this or maybe have the knowledge to help?
Thanks
AJPinto
  • Jul 17, 2024 7:30 PM UTC
You need to push the certificate with a Configuration Profile and set it to be available to all applications. Apple retired the ability to force trust a certificate in CLI with macOS 11. Basically -k does nothing anymore.
howie_isaacks
  • Jul 19, 2024 5:24 PM UTC
The method @AJPinto describes is the way we do ours. Our WiFi and Global Protect both use certificate based authentication. We distribute the certificates in a separate profile, specifically, the "auth" certificates. In the WiFi profile, we select this auth certificate in the Trust section.
Reboot2611
  • Jul 22, 2024 2:10 PM UTC
Hi @AJPinto In my environment I have deployed the certificate with Configuration Profile and set it to be available to all applications.Only the root certificate is deployed as Always Trust. The intermediate & leaf certificate is deployed as Use System Defaults so users are being prompted to Trust the certificate when they join the WIFI network. Am I missing something or how can I make sure the users are not prompted? Thanks
AJPinto
  • Jul 22, 2024 2:13 PM UTC
If the user is manually selecting the network, I would wager they are having to tell macOS which certificate the need network needs and not necessarily trusting the certificate. The only method I can think of for totally hands off is to have the Wi-Fi network configured with a Configuration Profile where you specify the Certificate the network needs.
Reboot2611
  • Jul 22, 2024 2:21 PM UTC
Thanks for your reply. I can give this a try and deploy the WIFI settings and Certificates in one config profile
