Question regarding policy execution via script......
  • January 11, 2019
  • 10 views
Hey all, when a script is used to execute policies.... example....
/blahblah/jamf policy -id ####
Does each policy finish 100% before it executes the next?
Also, I see people mentioning the ampersand (&) when referring to executing policies in scripts... how is that utilized please?
Thank you in advance!
1 reply
  • January 11, 2019
My understanding is that each policy has to finish before the next policy can run. As far as the & in a shell script or just in terminal you can string commands together using a double &&. For example I use the following often in terminal.
sudo jamf recon && sudo jamf policy && sudo jamf manage
Basically means:
Run the first command if it completes successfully run second command and if it completes successfully run third command.
You could also use a ; if you wanted the second and third command to run regardless of how the previous command finished.
