Questions about JAMF with other system
  • June 3, 2023
  • 0 replies
  • 15 views
Hi all. I am considering bringing up a way to better integrate Macs into our management system and wanted to check here to see if anybody had input. Currently we are using Automate and ScreenConnect for our clients as they primarily use Windows machines. However, there is a growing number of Macs entering the environment and it's not a shocker to say that Automate and SC are garbage with support and integration on macOS. I was wondering if having JAMF setup on the Mac side of things would work well in tandem with Automate. Or can it only be one or the other. Thanks.
