All,
I know this has probably been hashed over several times. We did some research and yet couldn't find a definitive answer. So I thought I would post a discussion to see how others are addressing this, if at all.
We got several hundred new Macs in and I am attempting to create new images and packages and the one I am struggling with is QuickTime pro 7. I have tried snapshotting the installation and that doesn't see to work well.
What we did is take a new base Lion image. Installed QT Pro 7.6.6 on it, registered the serial number and it becomes the pro version. All good. taking this new package and trying to install it either does one of two things.
The system will not allow us to login to it or the registration is not valid.
Any thoughts? Have any of you successfully packaged and deployed QT Pro 7 to a Lion based system? if so, can you share your secret or wisdom with me?
Thanks again...
Mick
