Re: Enrollment Fails Using the Casper Suite or Recon Suite v8.63 or earlier with MySQL 5.6
  • February 21, 2013
  • 23 views
donmontalvo
Forum|alt.badge.img+36
New KB provides a "fix" for the issue of our inability to enroll Macs:
https://jamfnation.jamfsoftware.com/article.html?id=318
However, it does not tell us if it is safe to roll back JSS if we are already running 5.6?
Can we shut down JSS, uninstall MySQL 5.6...then install MySQL 5.5 and start MySQL again?
Is this safe? Is it recommended?
PS, no option to post this question on the KB page...so posting here.
TIA
Don
Best answer by DavidSu
Hi Don,
Depending on the OS, a roll back of MySQL can be a little trickier than that. An alternative workaround for the error is to comment the sql_mode parameter out of the my.cnf/my.ini, and restart MySQL (this will disable strict mode). We'll get the KB updated to reflect this.
Thanks,
Dave
  • Employee
  • February 21, 2013
Hi Don,
Thanks,
Dave
donmontalvo
  • February 22, 2013
@david.suehring Thanks for the incredibly fast response and workaround. :)
We'll test this to see if it fixes the problem in our environment.
Don
donmontalvo
  • March 2, 2013
Sorry for the late response...your solution was spot on.
Don
