Some iPads have been removed from our JAMF pro instance before we unmanged them. Whats the easiest way to get them back in to JAMF?
Page 1 / 1
I should expand on this to say that they're locked down to a single app. So no browser or app store.
You will have to wipe the device using recovery or DFU as they cannot be managed if they aren't in the JSS, and they can only be added to Jamf during activation/enrollment
Using DFU to wipe the iPads worked fine, thanks for that.
