Rearrange order of "inventory display" columns in reports?
  • June 20, 2017
  • 12 replies
  • 290 views
Greetings JAMF Nation!
Apologies in advance if this has been covered and I've just missed it. I'd like to know if there is a way to rearrange the columns I choose to display when I check the items under "Inventory Display". I provided a screenshot to try to explain what I'm after...in my example, "last update" is the second column but I'm asking if there is a way to tell jamf to display that one at the end. So "name" then "model" then "OS" and finally "last update".
The end goal is to export the reports into an Excel spreadsheet but I'd like to not have to rearrange everything in Excel after it's exported. Would be nice to have it report in the order I want to export it.
-SP
  • January 7, 2020
I'm another person who would like to rearrange the columns in Inventory Display report. The current arrangement is makes it difficult to use the data presented. I would like the serial number and asset tag next to the Name followed by the iOS Version.
I also miss this feature...
  • January 7, 2020
There is no way to do this unfortunately. I believe there is an existing Feature Request that asks for it though.
Hello Team,
Arrangment of display inventory coloums should be there. We need this feature request.
  • February 12, 2021
I wanted to reorganise the columns as well - they appear in a random order
  • March 13, 2021
The original request is almost 4 years old. That's unfortunate. I'd like this feature, too.
  • September 16, 2021
I would also like this ability. It is definitely something that should be a basic feature.
eatkins
  • July 20, 2022
I too would like this
  • July 20, 2022
While Jamf has never provided a nice GUI way to rearrange the order of the columns, it IS actually possible to control their order, but the way to do it is extremely time consuming and painful to implement. It turns out that the order in which you add the columns to your report is the order that they show up in. In other words, if when going through the tabs when creating a report, if you click on Computer Name, then Last Inventory and then Serial Number or something like that, then your report will get generated in that exact order.
But... it gets even more complicated than this. I've found the only surefire way to get them columns to show up in an exact order is to save your report in between each selection. Yes, you read that right. You would have to click "Computer Name", click Save, click Edit, then click on "Serial Number", click Save, click Edit and then select "Last Inventory" and Save to get them in the order of "Computer Name", "Serial Number", "Last Inventory"
Obviously if you have a report that requires dozens of columns, this doesn't scale well at all. it could easily take you an hour to create a saved report that spits out the data in the order you want. And heaven forbid you realized you forgot to add one in. You basically have to start over. It's why Jamf really should add this in as a feature in some future version of the product. It's WAY too clunky, error prone and time consuming how it works now. And I'm pretty certain this isn't even really a feature, just a coincidence in how the database works.
opus-nbo
  • August 19, 2025
@mm2270 It’s even worse. Your description applies for saved searches but if you just hit the ‘Search’ button in the Inventory, the columns there are all over the place, ignoring the order of adding/checking them in inventory display settings.
DMH2000
  • October 15, 2025
Nope, nope, nope, in 2025 , they just populate wherever they want.
atomczynski11
  • October 15, 2025
ideas/JN-I-22451
Ability to customize order of display fields in Reports
I'm not able to link directly as the link is displayed incorrectly here.
