I am looking for recommendations on how to avoid the allow JAVA message to
appear when invoking the SAV LiveUpdate. (Our standard config enables the
firewall.)
I am not sure how to add JAVA to the exception list. When using the locate
function, there are several matches and paths to 'JAVA'.
Jason
There's not a way to programmatically add exceptions to the firewall. I confirmed this with AppleCare Enterprise.
On May 10, 2010, at 4:59 PM, Jason Halvorson wrote:
How I worked around it:
Built a preference file the way I wanted it. (Firewall preferences are stored in /Library/Preferences/com.apple.alf.plist). Using Composer, developed a .dmg which contains this preference file.
Wrote a script which:
1) stops the firewall
2) stops the firewall GUI (exact commands are in the Resource Kit)
And another script which:
1) starts the firewall
2) starts the firewll GUI (exact commands also in the Resource Kit)
Created a policy to run the first script before, then deploy the firewall preferences, then runs the second script after.
Worked like a charm. 10.6.3 caused some odd stuff to happen (firewall questions about items that were already in the GUI/in the preference file), so I ended up rebuilding the preference file on a 10.6.3 system, and now it's fine...
Hope this helps,
--Robert
@RobertHammen Your post about the Firewall preference file helped us. Thanks!
