Recon.exe
  • October 13, 2009
  • 4 views
Is it just me or has the documentation for using Recon.exe on PC's disappeared ? There is a version of Recon.exe in Casper 7.1
but there is nothing in the documentation about it.
You used to be able to add them using a command like this.
C:PrgCasperRecon.exe -autorun -server 10.1.1.1 -username username - password yourpassword
Is that still valid ?
Roger Corbin
Richmond SD38
  • October 13, 2009
Roger-
I had the same problem and found the below email chain, and most specifically the latest response directly below from Chad Brewer, to be most helpful. (Thanks Chad!)
Thanks,
Justin
  • July 5, 2012
no email chain listed? Any help???
