Recursive printer removal
Hi I want to recursively remove all printers of a certain model number with a script, what I have so far is the below but while testing the script seems to exit with 0.
function rmPrinters {
    thisPrinter=""
    thisPrinter=`lpstat -p | grep X7855 | head -1 | cut -d " " -f 2`
    if [ -z "$thisPrinter" ]; then
        lpadmin -x $thisPrinter
        rmPrinters{}
Can anyone help figure out why this is not working?
Best answer by davidacland
I haven't used -z before, is that to check if the variable is populated? The rest all looks ok so I'd assume it's that telling the script to exit 0.
Another way to see if the variable is empty would be:
if [ "$thisPrinter" = "" ]; then...
That aside, I'd probably go about it a different way using a loop:
counter=$(lpstat -p | grep -c X7855)
    # Outputs the number of found printers matching X7855
while [ $counter -ne 0 ]
    do
        thisPrinter=$(lpstat -p | grep X7855 | head -1 | cut -d " " -f 2)
        counter=$(( $counter - 1 ))
            # Reduces the counter by 1
done
davidacland
  • August 30, 2016
    do
done
iJake
Forum|alt.badge.img+23
  • August 30, 2016
First you can replace
with just an
awk '{print $2}'
Second, I think a for loop would work better and then there is no need for a counter.
  • August 31, 2016
@davidacland Thanks very much that worked a treat!
Have a great day.
