Relaxed Domains Cross-Site Tracking - No more manually toggling on/off!
  • July 5, 2024
  • 35 replies
  • 360 views
Show first post
  • January 7, 2025
@IT-CKrape, after installing the profile are you seeing the "Allow Cross-Website Tracking" under Settings > Apps > DRC Insight automatically turned on? See my above reply to wsievers.
Thanks for any insight!
@jr139 No, I am not seeing the slider under the DRC app altered by this profile installation.
From what I was able to find with DRC documentation, after a certain version of IOS the cross-site tracking slider was no longer necessary, but we have not found this to be the case.
After we installed this profile on our devices, the slider becomes irreverent and the students are simply able to access the content.  :-)
Hope this helps!
jr139
  • January 7, 2025
Hope this helps!
Many thanks for the quick reply! Hard to believe testing season is right around the corner.
  • January 7, 2025
@jr139 Yeah it is coming up quick!
My district elected to do the Firefly exams that DRC released this year, so we were able to test these profiles / settings in production with the students.  I can confirm that they work and that none of our students needed to access the DRC app settings to move the slider.
Since the Firefly exam really doesn't attach to any permanent / historically cached student information, it is a great trial run to ensure functionality if would like that extra peace of mind.  :-)
mshaw816
  • April 21, 2025
I used iMazing's Profile editor to create one, even though it's very simple as it had the "Relaxed Domain" category that Jamf Pro is missing from its domain section.
Is this available on the the free version?
mshaw816
  • April 21, 2025
Hello everyone,
I was successful in getting this to work. See the attached screen shot, it shows how we had to set it up with Jamf PRO and iMazing Profile creator. This was the response from DRC in my help ticket with them. Also attached below is a screen shot of my iMazing profile I uploaded to Jamf PRO.
You mentioned allowing "domains,"  please allow the specific URLs on those allowlisting tables from both the WIDA and Pennsylvania Technology User Guides (links provided in previous email) to be as specific as the DRC allowlisting tables specify.
Additionally, I came across this information from another user who was having a similar issue with getting his MDM to properly control their iPadOS 18.1 iPad's Cross-Website Tracking--maybe it will work for your MDM & iPads.
He said, "After adding the new key below to the mobileconfig file, we were able to log into WIDA DRC Insight without error, and did not have to manually enable the “Allow Cross-Website Tracking” toggle on each iPad.
<key>CrossSiteTrackingPreventionRelaxedApps</key>
<array>
<string>com.drc.wbte-ipad.drc</string>
</array>
Was this done with the free version?
mshaw816
  • April 21, 2025
Hello everyone,
<array>
</array>
iMazing that is
mshaw816
  • May 7, 2025
Hello all,
We’re receiving reports from teachers that during DRC testing on iPads, the “Prevent Cross-Site Tracking” setting keeps turning off after being manually enabled. I deployed the configuration recommended by @wsievers  and others, but some users are still reporting issues—specifically, that DRC testing doesn’t work unless this setting is enabled.
According to the documentation I’ve reviewed, iPads running iPadOS 16.2 and above shouldn’t require this setting to be on. However, users continue to experience errors until it is manually enabled. The main issue in our environment is that the setting does not stay enabled, and staff have to repeatedly toggle it back on.
Any ideas on this issue? Thanks in advance!
  • May 7, 2025
Hello all,
Good Morning,
I believe we have read the same documentation and I can confirm that the you will either need the configuration profile via iMazing or manually adjusting the slider.  Using the information on this post, we have been able to navigate Firefly, PSSAs, and Keystones without needing to manually check the DRC app "Prevent Cross-Site Tracking" options, so I would highly recommend the iMazing configuration for simplicity.
mshaw816
  • May 8, 2025
Good Morning,
Thanks! I was able to get the configuration profile set up after spending some time learning how to use iMazing. I tested it on a few iPads, and it appears to be working as expected. I’ve now scoped it to all managed iPads. I really appreciate coming across this thread—it was a big help!
atomczynski11
  • January 14, 2026
Created the profile in iMazing Profile Editor (not signed).
Uploaded it to Jamf Pro.
In Jamf Pro the description is missing and I’m not seeing any values under the Domain component.
Is that expected?
