remote login disabling using profiles
  • Dec 11, 2023 7:10 PM UTC
  • 4 replies
  • 422 views
hello all, does anyone know how to disable remote login using a profile/policy
  • Dec 11, 2023 8:48 PM UTC
The terminal command for disabling remote login is:
sudo systemsetup -f -setremotelogin off
So you should be able to create a policy with that line in Files and Processes > Execute Command to disable remote login on a computer.
  • Dec 11, 2023 8:50 PM UTC
(Except no sudo, since Jamf is executing as root already.)
AJPinto
  • Dec 12, 2023 2:37 PM UTC
The command @mdp should get the job done. However using the enable/disable Remote Desktop MDM command in under the Macs inventory record > Management > Management Commands is much faster. You can also issue the MDM command as a mass action.
  • Mar 1, 2024 1:33 AM UTC
I have a similar need to the OP and found this thread. Thanks so much!
I am going to assume from this that there isn't a config profile method that can be utilized to limit the removal?
