Remove JDS
  • August 27, 2013
  • 7 replies
  • 31 views
I would like to remove a JDS install, not only from the JSS using the GUI, but also the jamfds binary and associated files.
I would assume a sudo jamfds -removeFramework would exist, but this command failed.
Any ways of removing a JDS from a server?
also JDS nees to be added as a New Primary Application in the discussion Forums.
Best answer by erin_miska
Hey all,
In addition to the KB article linked above ("Components Installed on JDS Instances"), I've also posted a KB article on uninstalling a JDS instance:
https://jamfnation.jamfsoftware.com/article.html?id=340
Hope this helps.
-Erin
  • Employee
  • August 27, 2013
Hi Justin,
Yes, the commands to do this are a little different. Here you go:
Stop the JDS Launch Daemon:
sudo launchctl unload /Library/LaunchDaemons/com.jamfsoftware.jamfdspolicy.plist
Make a backup of the apache config file: /Library/Server/Web/Config/apache2/sites/0000_any_443_.conf
Copy the backup the JDS made into the sites directory:
sudo cp /Library/JDS/conf/.0000_any_443_.conf /Library/Server/Web/Config/apache2/sites/0000_any_443_.conf
Remove the JDS binary and associated files:
sudo rm /Library/JDS
sudo rm /Library/LaunchDaemons/com.jamfsoftware.jamfdspolicy.plist
sudo rm /usr/sbin/jamfds
Hope this helps!
  • August 28, 2013
Are these commands the same under Ubuntu?
  • September 2, 2013
I don't see how they could be given some of the file locations are different, and for the most part, ubuntu distributions don't use launchd
  • September 3, 2013
it was more of a leading question hoping someone would chime in the file locations or commands needed for removal on linux.
JAMF posted this which seems to answer the question
https://jamfnation.jamfsoftware.com/article.html?id=339
  • Employee
  • September 3, 2013
Hey all,
Hope this helps.
-Erin
  • September 3, 2013
Thanks Erin!
  • September 16, 2013
There is an error in the KB for RHEL and Ubuntu in the removal:
Reads:
sudo rm /usr/local/jds
sudo rm /usr/local/sbin/jamfds
It should be:
sudo rm -rf /usr/local/jds
sudo rm -rf /usr/local/sbin/jamfds
As these directories are not empty.
