I am using a simple AppleScript here to rename our computers before they get bound to AD. The computer name changes via the script, but as soon as it "Checks in" the names change back to MacBook Air. Occasionally it works fine and does not change back, but there is no rhyme or reason as to why. I have verified that NONE of my policies have the "Reset Computer Names " under the Maintenance Policy checked.
These are brand new machines never before logged in.
ComputerName=`/usr/bin/osascript << EOT
    activate
    set ComputerName to text returned of (display dialog "Please Input New Computer Name" default answer "" with icon 2)
end tell
EOT`
#Set New Computer Name
echo $ComputerName
/usr/sbin/scutil --set ComputerName "$ComputerName"
/usr/sbin/scutil --set LocalHostName "$ComputerName"
/usr/sbin/scutil --set HostName "$ComputerName"
echo "Rename Successful"
dscacheutil -flushcache
jamf recon
I know you mentioned you checked your policies but do you happen to have a Login Window Config Profile?
In that Config Profile payload is an option to "Set Computer Name to Computer Record Name"
Also have a close look at your other Config Profiles as well. I have been bit a few times where JAMF deploys a config profile with a "hidden" unrelated setting and causes some havoc.
I think you will need to change the computer name with the jamf binary command instead.
jamf setComputerName -name "$ComputerName"
We use the following script
NewComputerName="$(osascript -e 'Tell application "System Events" to display dialog "Enter the Asset ID Number:" default answer ""' -e 'text returned of result' 2>/dev/null)"
jamf setComputerName -name "$NewComputerName"
jamf recon -assetTag "$NewComputerName"
We do have a Login Window Config Profile! Thought for sure it would be this! But... verified that it is Not checked as well.
Verified the rest of our Config profiles as well. None of them have any settings for the name.
Going to RE-double check all of the policies again.
ammonsc - I'll give that a go and see if it holds any better for us.
@ammonsc I run the script locally and it works fine but it fails when deployed via policy or in SS any ideas?
@csanche3x , when running from a policy, the script is running as root, not as the local user, so the prompt is never shown to the use. Try this revised script:
currentUser=$( scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ && ! /loginwindow/ { print $3 }' )
NewComputerName="$(sudo -u $currentUser osascript -e 'Tell application "System Events" to display dialog "Enter the Asset ID Number:" default answer ""' -e 'text returned of result' 2>/dev/null)"
For more information, take a look at the JNUC presentation "Scripting Jamf: Best Practices" by Armin Briegel (scriptingosx). Here is a link his the resources page on his website ScriptingOSX-JNUC2020
@RBlount,Thank you very much for the script it's working as expected.
@RBlount
I put this script into Self Service and it seems to run just fine but there is nothing happening on the screen. Any idea what gives?
Never mind. Evidently it take a little bit!
