Required managed update daily notification
  • October 25, 2022
  • 4 replies
  • 182 views
janzaldua
Hi. A few users within our organization are having a daily pop-up that will not go away.
popup
Any idea on how to get rid of this?
atomczynski11
  • October 25, 2022
Do you have a computer profile with the following Payload?
Software Update
- Automatically install macOS updates
Have you issued a mass action command to update software?
hakimig
  • March 27, 2023
Software Update
Anyone figure out a fix for this? We do not have a payload but have issued a mass action command to update. But its only happening to some devices? Any help would be appreciated. Thanks
  • May 30, 2023
delete /Library/Preferences/com.apple.SoftwareUpdate.plist and reboot
hakimig
  • May 30, 2023
Thank you !
