Probably going to have to put the devices in an array and then have a foreach and send the command to each device
yuck, really?
Below is pretty much verbatim what the API example shows and returns "Bad Request" "Unable to match mobile_device"
curl -sku "${jssAPIUsername}:${jssAPIPassword}" -H "accept: application/xml" -X POST "${jssAddress}/JSSResource/mobiledevicecommands/command/RestartDevice/id/8%2C18%2C39%2C40%2C43%2C44%2C45%2C46%2C47%2C48%2C49%2C50%2C51%2C65%2C112%2C116%2C127%2C132%2C141%2C193%2C206%2C222%2C271%2C321%2C328%2C367%2C375%2C418%2C426%2C428%2C433%2C439%2C452%2C470%2C475%2C479%2C489%2C500%2C502%2C528%2C534%2C544%2C545%2C574%2C585%2C592%2C596%2C598%2C601%2C615%2C632%2C635%2C661%2C667%2C682%2C690%2C700%2C703%2C707%2C736%2C752%2C1182%2C1183%2C1184%2C1185%2C1186%2C1187%2C1188%2C1189%2C1190%2C1191%2C1192%2C1201%2C1202%2C1203%2C1252%2C1253%2C1254%2C1255%2C1256%2C1257%2C1258%2C1259%2C1260%2C1261%2C1262%2C1264%2C1265%2C1266%2C1267%2C1268%2C1269%2C1270%2C1271%2C1272%2C1273%2C1274%2C1275%2C1276%2C1277%2C1278%2C1279%2C1280%2C1281%2C1339%2C2030%2C2084%2C2136%2C2143%2C2726%2C2727%2C2728%2C2729%2C2730%2C2731%2C2732%2C2733%2C2734%2C2735%2C2736%2C2737%2C2738%2C2739%2C2740%2C2741%2C2742%2C2743%2C2744%2C2745%2C2746%2C2747%2C2748%2C2749%2C2750%2C2751%2C2752%2C2753%2C2754%2C2755%2C2756%2C2757%2C2758%2C2759%2C2760%2C2761%2C2762%2C2763%2C2764%2C2765%2C2766%2C2767%2C2768%2C2769%2C2770%2C2771%2C2772%2C2773%2C2774%2C2775%2C2776%2C2777%2C2778%2C2779%2C2780%2C2781%2C2782%2C2783%2C2784%2C2785%2C2786%2C2787%2C2788%2C2789%2C2790%2C2791%2C2792%2C2793%2C2794%2C2795%2C2796%2C2797%2C2798%2C2799%2C2800%2C2801%2C2802%2C2803%2C2804%2C2805%2C2806%2C2807%2C2808%2C2809%2C2810%2C2811%2C2812%2C2813%2C2814%2C2815%2C2817%2C3303%2C3304%2C3305%2C3306%2C3307%2C3308%2C3309%2C3310%2C3311%2C3312%2C3313%2C3360%2C3361%2C3362%2C3363%2C3364%2C3365%2C3366%2C3367%2C3368%2C3369%2C3370%2C3371%2C3372%2C3373%2C3374%2C3375%2C3376%2C3377%2C3378%2C3379%2C3380%2C3381%2C3382%2C3383%2C3384%2C3385%2C3386%2C3387%2C3388%2C3389%2C3390%2C3391%2C3392%2C3393%2C3394%2C3395%2C3396%2C3397%2C3398%2C3399%2C3400%2C3401%2C3402%2C3403%2C3404%2C3405%2C3406%2C3407%2C3408%2C3409"
Well dumping them into an array and running a bash for loop did the trick. It looks like there are still devices getting that error, but it isn't stopping the rest of them.
jssAPIUsername="USER"
jssAPIPassword="PASS"
groupid=32
jssAddress="https://myjamf:8443"
devices=$(curl -sku "${jssAPIUsername}:${jssAPIPassword}" -H "Content-Type: text/xml" "${jssAddress}/JSSResource/mobiledevicegroups/id/${groupid}" | xmllint --xpath //id - | sed -e "s/<id>${groupid}</id><id>-1</id>//" | sed -e 's/</id><id>/,/g' | sed -e 's/<[/]?id>//g' )
echo "~~~~~~~~~~~~"
IFS=',' read -ra devIDs <<< "$devices"
for x in "${devIDs[@]}";
do
data="<mobile_device_command><general><command>RestartDevice</command></general><mobile_devices><mobile_device><id>${x}</id></mobile_device></mobile_devices></mobile_device_command>"
curl -sku "${jssAPIUsername}:${jssAPIPassword}" -H "Content-Type: text/xml" "${jssAddress}/JSSResource/mobiledevicecommands/command" -d $data -X POST
echo ""
echo $x
echo "~~~~~~~~~~~~"
sleep 5
done
Needs lots of cleanup, but here it is.
I've done something similar with a Blank Push command.
Let's see.. you are POSTING so get rid of the -H section. The ID list needs to be comma separated not %2C.. assuming that is what you get in $devices I would try something like this:
curl -sku "${jssAPIUsername}:${jssAPIPassword}" "${jssAddress}/JSSResource/mobiledevicecommands/command/RestartDevice/id/"$devices -X POST
@maxbedford, I haven't fully vetted your command, but try setting your XML data to something like the following:
<general>
</general>
<mobile_devices>
<mobile_device>
<udid>DBD8086A-C09D-52CF-9C98-FA0E9B9CFB87</udid>
</mobile_device>
<mobile_device>
<udid>EDAE4A5C-0E22-4BB1-BD0B-08BA89916113</udid>
</mobile_device>
<mobile_device>
<udid>63620D2A-DFD1-42DF-9DC4-3FEE808B1C17</udid>
</mobile_device>
</mobile_devices>
or
<general>
</general>
<mobile_devices>
<mobile_device>
<id>247</id>
</mobile_device>
<mobile_device>
<id>358</id>
</mobile_device>
<mobile_device>
<id>400</id>
</mobile_device>
</mobile_devices>
If you put the pretty XML into a variable such as "THExml", you can use xmllint to flatten it just before you submit to the Jamf Pro Classic API:
flatXML=$( /usr/bin/xmllint --noblanks - <<< "$THExml" )
Try this @maxbedford
jamfProURL="https://acme.jamfcloud.com"
jamfUser=""
jamfPass=""
mobileDeviceGroupID=""
deviceIDs=( $( curl -k -s -u "$jamfUser":"$jamfPass" $jamfProURL/JSSResource/mobiledevicegroups/id/$mobileDeviceGroupID -H "Accept: application/xml" -X GET | xpath "//mobile_device_group/mobile_devices" | /usr/bin/perl -lne 'BEGIN{undef $/} while (/<id>(.*?)</id>/sg){print $1}' ) )
for i in ${deviceIDs[@]}; do
echo "Sending Restart Command to Device ID: $i..."
/usr/bin/curl -sk -u "$jamfUser":"$jamfPass" -H "Content-Type: text/xml" -d "<?xml version="1.0" encoding="ISO-8859-1"?><mobile_device_command><general><command>RestartDevice</command>></general><mobile_devices><mobile_device><id>$i</id></mobile_device></mobile_devices></mobile_device_command>" $jamfProURL/JSSResource/mobiledevicecommands/command/RestartDevice -X POST > /dev/null
if [[ "$?" == "0" ]]; then
echo " Command Processed Successfully"
echo " Error Processing Command"
echo ""
done
@cdenesha Thanks %2C is the ASCII code for a comma and somewhere I had seen reports of using that instead of a comma to fix issues.
@talkingmoose Thanks I tried a couple of different ways. At this point, I'm thinking about the solution that requires minimal parsing. It is good to know what XML format works.
@yoopersteeze Thanks! A lot of good pieces in there. I don't really want to bring Perl into this ATM.
I got it working and tested. Looking at using it to force iOS updates to our student population. That is the next step.
This does assume that the iPad is being used at the time that the command gets sent? Otherwise if the iPad is sleeping in a cart or locker or something, when the user turns it on next it will just immediately restart.
At no point in time have I made any statements on the assumption of the current state of the iPad,
I do understand that the iPad doesn't get the command immediately and that they get them when the iPad wakes back up, which as you point out maybe when the user next turns it on, it also maybe 2 minutes into a user waking up the iPad.
