Is there a trick to getting a computer to restore a wireless connection
after imaging? We have a common SSID and WPA key for wireless. My image
is created with the credentials saved and the wireless network is actively
connected on the computer. After imaging, the credentials are still there
in keychain and our network is listed in preferred networks but it won't
connect automatically. You have to login and select the wireless network
in the menu bar to make it connect.
This worked at one point, but maybe it was before we used Casper imaging.
I am pretty sure this wasn't a problem when I was creating my image with
NetRestore.
Thanks,
Chad
