Hi.
Is it possible to run a script on the 2nd login of a User?
This is in relation to FileVault.
We have followed the setup guide and this is working but we want to enable our local administrator as well.
This will run via a Script.
Or better: How do you ensure that your local admin accounts are enabled and able to log into a FileVaulted system?
Thanks
Not sure if you've figured out a way to do this yet. But one way could be to have a package run on first login of the user and then scope a smart group to run another script at login once that package has been run. This will mean that the user will login the first time, run the dummy package, run recon, the machine will be scoped to your smart group, next login the other policy will run.
If you want any more info, or a clearer description :) just let me know.
Cheers
