Running Unix Commands Via Jamf
  • October 2, 2014
  • 9 views
Hi All,
I am trying to push a few terminal commands via jamf to users machines. I wrote the script up and it states it has completed the deployment successfully. When i go to test what the script is supposed to do, there are no changes. I need this to run as the local user. I understand that by default it runs as root. Below is my current apple script.
do shell script "sudo defaults write com.google.Chrome AuthServerWhitelist '<Domain>'"
<Domain>'"
donmontalvo
Forum|alt.badge.img+36
  • October 2, 2014
  • October 7, 2014
Agree…use a configuration profile for this. So much easier to do and maintain. If you need help let me know and I can shoot you a sample of the file I use.
