Since the release of the Safari 10 update, we've encountered a strange issue where a small handful of clients will no longer open the browser. Nothing in the logs and not even a single bounce in the dock when clicked. It occurs under all users on the affected machine and when opened via the Terminal, all that's returned is "LSOpenURLsWithRole() failed with error -10699 for the file /Applications/Safari.app"
What's even stranger is Safari can be opened by Show Package Contents on Safari.app then opening the executable within the Contents/MacOS folder.
Anyone have any ideas?
Is this on 10.11? A couple of people here resolved it by reinstalling the recent 10.11 security update. YMMV...
Unfortunately for us, reinstalling the security update did not fix any of the machines affected with this. However, upgrading to Sierra seems to fix.
I've been able to fix the problems by installing a copy of the Safari 10 installer that was downloaded to a system but not yet installed. Find the downloaded installer in /Library/Updates.
A reinstall ended up fixing it for my clients, if you need the download and don't want to hunt down a machine that hasn't received it yet, you can download it from Apple here:
http://swcdn.apple.com/content/downloads/13/52/031-78814/r747w78fqi2jru2xuiihjhnedprlwz1ubg/Safari10.0ElCapitan.pkg
Thanks, all - that just fixed the issue for me, as well.
This just happened to me. The fix offered by @mikeh worked. Its actually what Apple Support had me do. My question is: why is this happening? And why isn't it happening to everyone in the environment? Hopefully Apple with come up with a reason.
I literally just received a call about this reappearing 5 minutes before your reply... I ended up doing the same thing as last time, but needed Safari 10.0.1:
http://swcdn.apple.com/content/downloads/44/57/031-81873/b7woxaez0lftqe660ikhdui2cmzcuktqmo/Safari10.0.1ElCapitan.pkg
Thanks for this solution, it helps a lot. But how did you find the downloadlink at the swcdn-Site of Apple? I tried to search but it failed. For the future it would be very helpful to find there some downloads of apple software. Thanks in advance for helping
Apple doesn't provide those directly on Apple.com anymore, you can find them in the software update catalogs:
https://gist.github.com/geoff-codes/c7b38d695af39c4e1535
