Scheduling rebooting of machines
  • April 2, 2020
  • 28 replies
  • 332 views
I have seen bunch of scripts online but if someone has a working script which can deploy will be very helpful.
I am looking a script which checks the last reboot of the machines. Then it would check if the reboot occurred less than 7 days or not. If the user hasn't rebooted for more than 7 days, the script will restart their machines. They will receive a popup that their laptop will be restarting and also allows them to extend the time by few hours before the laptop restarts.
  • April 10, 2020
I am very interested in this as well - lack of reboots has been problematic in our enterprise.
  • April 12, 2020
Hi @tegus232 ,
I'd start with the following Extension Attribute to check the last day the machine was rebooted. Make sure to set the Data Type to Date Format.
#https://www.jamf.com/jamf-nation/discussions/10009/uptime-or-last-shutdown-restart#responseChild55774
echo "<result>$(date -jf "%s" "$(sysctl kern.boottime | awk -F'[= |,]' '{print $6}')" +"%Y-%m-%d %T")</result>"
Then I'd create a Smart Group to check for machines that have not rebooted in over 7 days
I'd then set a policy to run a script like below to the user's machine.
Jamf Helper Reboot Script with Deferral
(You could probably bypass the EA creation and store the script natively on user's machines. You could call it via a Launch Agent, but I personally prefer Jamf handling the script deployment)
I have not tested this workflow.
  • May 15, 2020
How did you get Criteria "Uptime"
sdagley
  • May 15, 2020
@jschank The first part of @shaquir's post is an Extension Attribute (EA) to collect the info from a Mac during inventory, and he named the EA Uptime. When you're creating a Smart Group, click the Show Advanced Criteria button when adding Criteria, and you will then see all of the EAs being collected by your JSS.
atomczynski11
Here is what I have...
The Mac Admin community has been helpful and I got this working.
With this, the user has the option to select time of restart, or cancel.
### Adam T.
### April 16, 2020
### This is a JamfHelper Script which will be used to notify user if they have not restarted the computer in 7 days
### This script will give the user options how to proceed (now, 1 min, 5 min, 30 min 1 hr, 2 hrs as an example)
### This is needed as staff members tend not to restart their computers often
### This script is called from another script that checks uptime
### Using Jamf Helper is cool
#Message type variables below
#Utility window gives a white background
window="utility"
title="Replace this text to enter the title of the notification"
heading="Please restart your computer (modify as needed)"
description="Your computer has not been restarted in at least seven days. A more frequent restart is recommended.
Doing so optimizes the performance of your computer as well as allows us to deploy security updates or new applications to you automatically.
Please restart now."
icon="/System/Library/CoreServices/Software Update.app/Contents/Resources/SoftwareUpdate.icns"
selection=$("/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper" -windowType "$window" -title "$title" -heading "$heading" -description "$description" -icon "$icon" -button2 "Restart"  -showDelayOptions "0, 60, 300, 3600, 7200" -button1 "Cancel" -cancelButton 1)
buttonClicked="${selection:$i-1}"
timeChosen="${selection%?}"
## Convert seconds to minutes for restart command
timeMinutes=$((timeChosen/60))
## Echoes for troubleshooting purposes
echo "Button clicked was: $buttonClicked"
echo "Time chosen was: $timeChosen"
echo "Time in minutes: $timeMinutes"
if [[ "$buttonClicked" == "2" ]] && [[ ! -z "$timeChosen" ]]; then
    echo "Restart button was clicked. Initiating restart in $timeMinutes minutes"
    shutdown -r +${timeMinutes}
elif [[ "$buttonClicked" == "2" ]] && [[ -z "$timeChosen" ]]; then
    echo "Restart button was clicked. Initiating immediate restart"
    shutdown -r now
elif [ "$buttonClicked" == "1" ]; then
    echo "Cancel button clicked. Exiting..."
exit
sdagley
  • May 15, 2020
@atomczynski Be aware that by using shutdown -r now the Policy running this script will never get logged since it'll kill the jamf agent before it can log completion with your JSS.
beeboo
  • May 19, 2020
shutdown -r +1 &
i use that at the end of my OS upgrade script
seems to give it enough time to let JSS know of the results (note, not doing a recon or anything)
that way a user doesnt get prompted multiple times to run the policy before a recon kicks in and theres no point running a recon before the upgrade as i need the new upgrade info post reboot.
  • March 1, 2021
This is great.
The only issue I am experiencing is, the delay option does not seem to work, my checkin is every minutes, if I select anything greater than 15 min in the script it will re run the script on checkin
Any suggestions to get around this
beeboo
  • March 1, 2021
every how many minutes?
Ours is set to 30 min and its fine, but it also depends on what you want to do.
Occasionally we see this when it comes to large downloads like OS or when a user has a slow internet connection, but my understanding is that when a script is running it wont prompt you again, UNLESS its waiting for your confirmation (we have cases when we auto kick off policy in X minutes and a user might get 2 prompts).
But i could be wrong about the policy part, though logically it should make sense.
  • November 29, 2021
### Adam T.
### April 16, 2020
window="utility"
    shutdown -r now
exit
Hey @atomczynski11 I do not see the logic where the script checks for the 7 days
sdagley
  • November 29, 2021
@Anton11 The script doesn't check for uptime, that's done via an Extension Attribute to report Uptime and a Smart Group to determine if the value of Uptime is more than 7 days which is used to scope a Policy which runs the script above.
ejadadic
  • April 12, 2022
### Adam T.
### April 16, 2020
window="utility"
    shutdown -r now
exit
Is there a way to run a launch daemon every 8 hours?
sdagley
  • April 12, 2022
@ejadadic Use a <key>StartInterval</key> with <integer>28800</integer> as the value in your LaunchDaemon .plist.
And here's a handy web site for creating schedules for a LaunchDaemon: https://zerolaunched.herokuapp.com
  • April 13, 2022
Question.. do you need to set an inventory update to occur at reboot to keep this from looping? the script will only recognize the new timestamp after an inventory update.
  • April 13, 2022
nvm, I just added an inventory update at reboot.. thought I had that checked before..alas..
ejadadic
  • April 13, 2022
Thank you for that information, can I simply input that in the script itself or compose the script and launchagent into a package?
sdagley
  • April 13, 2022
@ejadadic The StartInterval goes into your LaunchDaemon .plist. It doesn't matter if you have a wrapper script that writes out the LaunchDaemon and the script it's going to call, or if you have a .pkg install the LaunchDaemon and script.
ejadadic
  • April 14, 2022
I've been getting some issues on devices trying to restart
Shutdown at Thu Apr 14 00:09:23 2022. shutdown: can't detach from console
  • September 18, 2022
### Adam T.
### April 16, 2020
window="utility"
    shutdown -r now
exit
Hi
Q about the script that is working perfectly,
In the defer options - can I change the Start now option to Reboot now?
  • January 18, 2023
Did you create a seperate policy for this to force a group with X amount of days to update inventory at login?
  • April 19, 2023
I recently put this one together but I feel like it's not working exactly how I want. It detects the first portion of over 10 days but not the 14. I think it's canceling itself out. Feel free to share some input to make this better.
Maybe I should put the higher integer first?
#!/bin/sh ######################################## # # A+E Reboot 2.0 script by David Maestre # # Detects machine uptime and uses logic to engage secondary policy. # 1. Reboot prompt to remind user to restart machine soon. # 2. Force reboot machine prompt when they surpass 14 days uptime. # 3. Machine compliant, policy zeros out and exits. User never disturbed. # ####################################### # Check if the last reboot was more than 10 days ago last_reboot=$(sysctl -n kern.boottime | awk -F'[ ,]' '{print $5}') current_time=$(date +%s) elapsed_time=$(uptime | awk {'print $3'} | sed 's/,/ /g' | sed 's/d/ d/g') int1="10" int2="14" # Check to see if reboot is required if [ $elapsed_time -gt $int1 ]; then echo "over 10 days - reboot policy engaged" /usr/local/bin/jamf policy -event restart-reboot-prompt elif [ $elapsed_time -gt $int2 ]; then echo "over 14 days - forcing restart" /usr/local/bin/jamf policy -event force-reboot-prompt else echo "Machine is Reboot Compliant" exit 0 fi
  • April 20, 2023
Yup, that did the trick I believe. I flipped the IF statements to have the higher integer first. Now it's working as it should.
Feel free to use/test in your environment.
  • October 10, 2023
Tried every script possible but none seem to work.
Forum|alt.badge.img+15
  • October 10, 2023
@egusman I used @atomczynski11's script above. We haven't implemented a 7-day reboot policy yet but wanted to make sure I had something ready. When I tested it, everything worked fine. After my device was online for over 7 days it fell into a smart group which I have my policy scoped to.
I was able to delay it if I wanted to or reboot it. I did change the delay options times in the script.
#!/bin/bash ################### ### Adam T. ### April 16, 2020 ### This is a JamfHelper Script which will be used to notify user if they have not restarted the computer in 7 days ### This script will give the user options how to proceed (now, 1 min, 5 min, 30 min 1 hr, 2 hrs as an example) ### This is needed as staff members tend not to restart their computers often ### This script is called from another script that checks uptime ################## ### Using Jamf Helper is cool ################# #Message type variables below #Utility window gives a white background window="utility" title="Reboot Needed" heading="IMPORTANT: A system reboot is required. Please close all applications and restart your computer." description="Your computer has not been restarted in at least seven days. A more frequent restart is recommended. Doing so optimizes the performance of your computer as well as allows us to deploy security updates or new applications to you automatically. To prevent receiving this message in the future, please reboot your computer at least once per week. NOTE: Use the dropdown below to select a time of when you want to reboot then click Restart. Your device will reboot automatically based on the time you selected." icon="/System/Library/CoreServices/Finder.app/Contents/Resources/Finder.icns" selection=$("/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper" -windowType "$window" -title "$title" -heading "$heading" -description "$description" -icon "$icon" -button1 "Restart" -showDelayOptions "0, 60, 3600, 7200, 14400, 28800") ## The Original line below #selection=$("/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper" -windowType "$window" -title "$title" -heading "$heading" -description "$description" -icon "$icon" -button2 "Restart" -showDelayOptions "0, 60, 3600, 7200, 14400, 28800" -button1 "Cancel" -cancelButton 1) buttonClicked="${selection:$i-1}" timeChosen="${selection%?}" ## Convert seconds to minutes for restart command timeMinutes=$((timeChosen/60)) ## Echoes for troubleshooting purposes echo "Button clicked was: $buttonClicked" echo "Time chosen was: $timeChosen" echo "Time in minutes: $timeMinutes" #Changed Line 49 and 52 from 2 to 1 if [[ "$buttonClicked" == "1" ]] && [[ ! -z "$timeChosen" ]]; then echo "Restart button was clicked. Initiating restart in $timeMinutes minutes" shutdown -r +${timeMinutes} elif [[ "$buttonClicked" == "1" ]] && [[ -z "$timeChosen" ]]; then echo "Restart button was clicked. Initiating immediate restart" shutdown -r now #elif [ "$buttonClicked" == "1" ]; then #echo "Cancel button clicked. Exiting..." exit 0 fi exit
  • October 11, 2023
Works perfectly well! Thanks a lot.
