Script Error help
  • October 24, 2013
  • 16 replies
  • 41 views
following script being deployed via casper remote or policy
osascript -e 'tell application "System Events" to delete login items';
and I get the following error: Runs perfect when run through local terminal
Mounting Casper Distribution to /Volumes/casper...
Running script Clear Login Items.sh...
Script exit code: 1
Script result: 43:54: syntax error: A plural class name can’t go after this identifier. (-2740)
Any help would be appreciated.
Best answer by mm2270
This may be overkill, but you could try this-
loggedInUser=$( ls -l /dev/console | awk '{print $3}' )
loggedInPID=$( ps -axj | awk "/^$loggedInUser/ && /Dock.app/ {print $2;exit}" )
/bin/launchctl bsexec "${loggedInPID}" sudo -iu "${loggedInUser}" "open /Users/Shared/DeleteLoginItems.app"
Stolen, err, borrowed code from others here that have done this before me. I use similar syntax in another script that has to call terminal-notifier.app as the logged in user.
If the above works, I'd go back and try using your original osascript code above instead of the call to an app to see if that works as well. Only thing is, you need to backslash escape any quotes in the osascript line (singles or doubles) or it won't work.
  • Employee
  • October 24, 2013
Remember Casper is going to be running your scripts as the root user, not the locally logged in user... you may need to create a variable for the currently logged in user and then use a "sudo -c" to get it done...
  • October 24, 2013
I have tried
sudo -u "$loggedInUser" /usr/bin/osascript -e 'tell application "System Events" to delete login items'
Same error.
Forum|alt.badge.img+31
  • October 24, 2013
Hey Everyone,
I have seen this before when using Applescripts to migrate end user's exchange server settings in Outlook. I actually had to save my Applescript as an application, and then run the open command to have the user open it. I think this is due to some of the newer sandbox environments OS X has added since 10.7. So, I would save the Applescript as an app and toss it in my scripts folder in my CasperShare. Then run something like this:
currentUser=$(ls -l /dev/console | awk '{ print $3 }')
sudo -u ${currentUser} open /Volumes/CasperShare/Scripts/myapplescript.app
The code would execute as that end user, and it would run like an app instead of an actual Applescript. This is how I got around the whole run as root and sandboxed environments of OS X.
Hope this helps you,
Tom
  • October 24, 2013
fails out with the following error
Script exit code: 0
Script result: LSOpenURLsWithRole() failed with error -10810 for the file /Users/Shared/DeleteLoginItems.app.
  • October 24, 2013
Hi msardes,
This is what I did and I just double checked this in my test environment:
Open Applescript Editor and create this script:
    delete login items
end tell
Then export that script to an application, via the export menu. I have a local test account on my Macbook Pro named, "Tom Waits." The shortname is 'tomwaits,' and I fast user switched to that user, opened up a terminal session, switched the terminal session to the root user, and opened the app from my home folder, as root, but as the currently logged in user:
bash-3.2# whoami
root
bash-3.2# sudo -u tomwaits open /Users/tlarkin/Desktop/deleteLoginItems.app
bash-3.2#
In return the start up items I set for the user account Tom Waits, were in fact deleted. I had added Safari and VMware Fusion assistant as two start up items. If this is further not working for you I will toss it in my virtual JSS when I have a few minutes later today to fully test. As of right now I have only tested it locally. I did get the expected results though.
I hope this fixes it,
Thanks,
Tom
  • October 24, 2013
it all works fine when I run in terminal locally however its when i run a script invoking the app that I get the error.
Script
sudo -u ${currentUser} open /Users/Shared/DeleteLoginItems.app
  • October 24, 2013
  • October 24, 2013
Could you post both your apple script and the bash script you are using to run it?
Thanks,
Tom
  • October 24, 2013
as in:
sudo -u "$loggedInUser" /usr/bin/osascript -e ' ell application "System Events" to delete login items'
  • October 24, 2013
as in:
  • October 24, 2013
AppleScript
tell application "System Events" delete login items
end tell
Shell Script:
alternatively I would just like this to work with shell script as in:
  • October 24, 2013
@msardes
Almost right/ Make sure to put the backslashes before the quote marks for one, not after them. Also, quote the entire command you're instructing the script to run as the user. So like this
sudo -iu "$loggedInUser" "/usr/bin/osascript -e 'tell application "System Events" to delete login items'"
Lastly, note I'm using sudo -iu, not sudo -u
  • October 24, 2013
script changed to
following error:
Running script Delete Login Items.sh...
Script exit code: 1
Script result: 0:1: syntax error: A unknown token can’t go here. (-2740)
  • October 24, 2013
btw the apple scrips one worked however If I can just do this with a shellscript that would rock.
  • October 24, 2013
ok doing this:
Delete Items apple script app in /Users/Shared
this shell script to invoke at login
sleep 1
works great, thanks guys and girls.
  • August 5, 2014
mm2270 you legend, that works a treat.
