script for - Allow authentication from any domain in the forest
  • December 1, 2015
  • 4 replies
  • 22 views
Hi All
As above, does anybody know of a way I can remotely uncheck the above option on our macs?
Its in the AD bind section, they are all bound to our AD but i would like to uncheck this without going to every machine to do so.
Thank you
Bill
Best answer by mm2270
sudo dsconfigad -alldomains disable
But, if you push it from Casper, drop the sudo as it won't be needed.
You should read through the man page for dsconfigad as well to get familiar with everything it can do.
man dsconfigad
  • December 1, 2015
man dsconfigad
davidacland
  • December 1, 2015
Not sure if it's still the case but you may need to change the search domains as well. They'll be pointing to all domains otherwise.
  • December 2, 2015
Is that the "Prefer this domain server" option?
apizz
Forum|alt.badge.img+15
  • December 2, 2015
@billystanton, the -preferred [server] command in dsconfigad is for setting a preferred domain controller
