Script help?
  • June 21, 2011
  • 6 replies
  • 24 views
ImAMacGuy
Forum|alt.badge.img+23
So we have had an issue with our M$ Messenger and finally got a fix for
it today. The downside is that it requires a bit of terminal
interaction. What would be the best way to go through this as we have
to deploy to about 500 machines...
* Save attached file without the .TXT extension.
* Open Keychain Access from Applications/Utilities.
* Go to File->Add Keychain.
* At this point you are in ~/Library/Keychains. Browse to
/System/Library/Keychains and add X509Anchors.
* Right-click the newly added keychain and unlock it.
* Open Terminal from Applications/Utilities.
* sudo chmod -R 777 /System/Library/Keychains
* Double-click the certificate and add it to the X509Anchors
keychain.
* Go back to your terminal window. If you closed it, just open
another.
* sudo chmod 755 /System/Library/Keychains (no -R this time as
the files inside have different permissions)
* sudo chmod 644 /System/Library/Keychains/*
* Close Terminal and Keychain Access.
John Wojda
Lead System Engineer, DEI & Mobility
3333 Beverly Rd. B2-338B
Hoffman Estates, IL 60179
Phone: (847)286-7855
Page: (224)532.3447
Team Lead DEI: Matt Beiriger
<mailto:mbeirig at searshc.com;jwojda at searshc.com?subject=John%20Wojda%20Fe
edback&body=I%20am%20contacting%20you%20regarding%20John%20Wojda.>
Team Lead Mobility: Chris
<mailto:cstaana at searshc.com;jwojda at searshc.com?subject=John%20Wojda%20Fe
edback&body=I%20am%20contacting%20you%20regarding%20John%20Wojda.> Sta
Ana
Mac Tip/Tricks/Self Service & Support
<http://bit.ly/gMa7TB>
"Any time you choose to be inflexible in your approach to an
unpredictable project you are already building failure into your plan"
you shouldn't change the keychain's mode to 777, but you should use /usr/bin/security to add your certificate.
see this for example syntax for adding a properly formatted cert to the system keychain.
https://github.com/tspgit/luggage/blob/master/802.1x_profile_10.5/postflight
  • June 21, 2011
I deployed our cert to the root level via policy and then ran the following
to add it to the Keychain in an After script.
security add-trusted-cert -d -k "/System/Library/Keychains/X509Anchors"
/certnew.cer
rm /certnew.cer
Ryan M. Manly
Glenbrook High Schools
  • June 21, 2011
x509 anchors is deprecated. Use System if possible.
j
Jared F. Nichols
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
ImAMacGuy
  • June 21, 2011
We tried system, couldn't get it to run.
  • June 21, 2011
Let's just say you should get that sorted if you've got plans for Lion. :)
j
Jared F. Nichols
244 Wood Street
781.981.5436
  • June 23, 2011
It was hard coded to look in X509Anchors.
I don't know if this has changed at all in Messenger/Communicator updates. I
know that it did not work with System when I was doing this a year or so
ago.
Luckily I don't have to deal with it now as the administration has decided
they do not want the legal ramifications of logging IM sessions etc.
Ryan M. Manly
