Script Help for Extenstion Attribute to collect String
  • October 10, 2014
  • 62 views
I am trying to collect a string from the OEAO plist. The script I wrote works via ARD, but does not work as an EA in Casper. Any ideas as to what I am doing wrong? Is there a better way to collect the string for the destinationFolder Key?
loggedInUser=/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }'
/usr/libexec/PlistBuddy -c "print :destinationFolder" /Users/$loggedInUser/Library/Preferences/com.softhing.oeao3.plist
Best answer by brad
For extension attributes you will need to put the output in between results tags.
So something like this:
loggedInUser=`/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }'`
destinationFolder=`/usr/libexec/PlistBuddy -c "print :destinationFolder" /Users/$loggedInUser/Library/Preferences/com.softhing.oeao3.plist`
echo "<result>$destinationFolder</result>"
Good luck!
Forum|alt.badge.img+15
  • October 10, 2014
Good luck!
  • October 14, 2014
That worked. Thank you!!
