Script Help To Delete a Folder
I need to delete the following folder.
/Library/StartupItems/ES1000Service
Can someone help me out with creating a script to do this? The ones that i have tried do not seem to work.
Thanks,
Jim
Best answer by krichterjr
Since this is just a "one-liner", I would just copy + paste this into the "run command" field of the "Advanced" section where you create a policy. You could create an actual script and upload it to Casper but it's probably more work than what it's worth.
rm -R /Library/StartupItems/ES1000Service
If you run through Terminal.
sudo rm -R /Library/StartupItems/ES1000Service
If you run it through Casper you don't need sudo as it will automatically run as root.
  • February 7, 2014
Thanks if I want to run it in casper dont I need the bin bash in front?
Forum|alt.badge.img+21
  • February 7, 2014
I like to give the full path to commands as well as to files. This assumes your partitions never get renamed from Macintosh HD. Always test.
/bin/rm -rf /Volumes/Macintosh HD/Library/StartupItems/ES1000Service/
  • Employee
  • February 7, 2014
  • February 7, 2014
Thanks immaging some new computers for Graphics and we noticed that one of the blasted Fiery packages creates this silly folder. In place of redoing everything I am just adding the post imaging script for the rest of the macs, and then pushing this script to the ones we deployed already.
It seems to have worked on so far.
  • February 10, 2014
Why not just use the "Files and Folders" object tin a policy to delete the folder?
donmontalvo
Forum|alt.badge.img+36
@JimAllsop I posted this concern to the EFI forum and received a private response, hopefully we'll see an updated installer that addresses some concerns.
Fiery Command Workstation 5.7 concerns (OS X)
donmontalvo
FYI...EFI responded to the thread. ;)
donmontalvo
donmontalvo
Woah, that was quick - thanks EFI!!!
Ether beer for EFI!!!
donmontalvo
gskibum
  • May 14, 2015
Don, thank you for pursuing that. Fiery software definitely makes me go grrrrrrrr.
