Script help to log off and clear desktop on shared machine
  • Oct 29, 2025 8:53 PM UTC
  • 5 replies
  • 169 views
So I posted asking for help on this here site with a script to automatically force log off users after 30 minutes and to wipe the desktop. A helpful soul provided me with something which does that and deletes the profile which does clear the desktop. Unfortunately that would not work for the people requesting this and they came back with a new wrinkle: they wanted 2 desktop shortcuts to a couple of websites which need to be preserved when the log out and wipe takes place.
I thought I found the right way to go which works in Terminal as well as when the following lines are in their own script in Jamf.
find /Users/libuser/Desktop -type f -not -name "Click Here to Open a Ticket with ITS.webloc" -and -not -name "Library Homepage.webloc" -exec rm {} \;
killall loginwindow
The problem is, the find command doesn’t run even though the killall loginwindow one does. If I can just get the find command to run then I’ll be all set. I read that maybe glob would work better instead of find here but I can’t find how to replicate what the find command does.
Here is the full script with the above lines embedded that partially works (I know the timeout is only 60 seconds but I was doing that for testing):
cat << EOF > /usr/local/bin/forcelogout.sh
log="/Library/Logs/Auto_Logout/Auto_Logout.log"
writelog() {
local log_file="/Library/Logs/Auto_Logout/Auto_Logoutlog"
echo "\$(date '+%Y-%m-%d %H:%M:%S') - \$1" >> "\$log_file"
mkdir -p "/Library/Logs/Auto_Logout"
lidClosed=\$(ioreg -r -k AppleClamshellState -d 4 | grep AppleClamshellState | head -1 | awk '{print \$NF}')
if [[ "\$lidClosed" == "Yes" ]]; then
writelog "Lid has been closed while still logged in; logging out."
osascript -e 'tell application "loginwindow" to «event aevtrlgo»'
rm -r /private/var/libuser
writelog "Lid is not closed; exiting."
IdleTimeSecs=\$(expr \$(ioreg -c IOHIDSystem | awk '/HIDIdleTime/{print \$NF; exit}') / 1000000000)
IdleLimit="60"
if [[ "\$IdleTimeSecs" -gt "\$IdleLimit" ]]; then
writelog "Idle limit reached. Logging out user."
killall loginwindow
EOF
cat << EOF > /Library/LaunchAgents/com.apple.forcelogout.plist
<plist version="1.0">
<dict>
<key>Label</key>
<string>com.apple.forcelogout</string>
<key>ProgramArguments</key>
<array>
<string>/bin/bash</string>
<string>/usr/local/bin/forcelogout.sh</string>
</array>
<key>StartInterval</key>
<integer>15</integer>
</dict>
</plist>
EOF
chmod 644 /Library/LaunchAgents/com.apple.forcelogout.plist
chown root:wheel /Library/LaunchAgents/com.apple.forcelogout.plist
/bin/launchctl load /Library/LaunchAgents/com.apple.forcelogout.plist
Anyway, I appreciate any help here and if there’s a different way of doing the same thing I’m open to it.
  • Oct 29, 2025 8:56 PM UTC
Can you add the webclips to the dock?
  • Oct 29, 2025 9:01 PM UTC
If this is a kiosk machine, why not enable the guest account and force a logout from there? It would clean up any changes.
  • Oct 29, 2025 10:07 PM UTC
As ​@_gsm said if it’s a kiosk style of device I would be tempted to go that way to handle the wiping.
Having said​ that, @heavymeta80 it’s not something as simple as putting the full path to the find binary is it? i.e. in the script instead of putting
change it to
/usr/bin/find /Users/libuser/Desktop -type f -not -name "Click Here to Open a Ticket with ITS.webloc" -and -not -name "Library Homepage.webloc" -exec rm {} \;
Worse case it might be that it wants the command to be run as the user.
Hope that helps
PaulHazelden
  • Oct 30, 2025 10:49 AM UTC
If the main script is working well, but removes everything. I would be tempted to leave that alone and set up a LaunchAgent to run a script to put them back. This will run at every login, and will put them in place. You can either have the script make the shortcuts, or if you put a copy of them in a safe location, the script can copy them into place.
  • Oct 30, 2025 5:34 PM UTC
Thank you all! I ended up taking the suggestion of ​@_gsm and placed the clips on the dock. Now for some reason the command to wipe the desktop isn’t working when the machine logs off. It worked in Terminal but not in the script:
rm -rf "/Users/libuser/Desktop/"
I know this is super easy but it’s just not clicking for me today.
