Script set to run AFTER IMAGING ??
  • March 8, 2016
  • 6 views
Forum|alt.badge.img+20
when does this actually happen? after the OS has been installed?
I want this particular script to be the last thing that runs in this particular configuration, after the OS and all other applications/Scripts that my configuration has in it have run.
i have other scripts to run AT REBOOT and applications with Priority of 10/15.
Best answer by davidacland
Yep, "after imaging" would run before any postponed installs set to run at reboot.
  • March 8, 2016
I set it AT REBOOT and looks like based on the configuration workflow (i'm running it right now) that the script is running last.
davidacland
  • March 8, 2016
