I am looking to update our script which mounts shared files using Monterey.  I believe the issue is python being out of date - any suggestions would be helpful.  Here is our current script for Big Sur...
LoggedInUser=$(python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "\\n");')
su "$LoggedInUser" -c '/usr/local/bin/dockutil --add smb://fs1.vcs.local/Shared\\ Files --label 'Shared Files' --position end'
If this is not where this post belongs, please let me know
Try this
LoggedInUser=$(ls -l /dev/console | cut -d " " -f4)
If you are using the latest dockutil package (rebuilt in swift) which removes python dependancy, try dropping the su to impersonate the logged in user.
I found updating their dock plist alone, was what now worked for me.
https://community.jamf.com/t5/jamf-pro/dockutil-script-revised-for-monterey/m-p/263826/highlight/true#M242672
