Are anyone else's script views being limited to 14 lines? What gives?
This seems to be related to which version of Jamf Pro you're on. For example, we're still on an older release and ours is limited to 24 lines. Still woefully small, but a little better than 14. I honestly don't understand why there is any limit at all. I should be able to see the entire script and just scroll my screen and not only see a limited portion of it inside a window. Makes no sense.
The Jamf Pro script editor is both a blessing and a curse. It's great we can make edits to our script and create new ones in place, but trying to use it as a full script creation or editing tool gets frustrating really fast. I never do more than very minor edits within that UI. For any larger edits, I use BBEdit or Visual Studio Code for editing and then copy/paste over the script in Jamf Pro. This also allows for localized testing, which is a good idea before overwriting a script in your Jamf repository anyway.
To be fair, I don't think Jamf ever intended for the built in script editor to be anything but a quick editing window and not intended to be used for major writing or editing of scripts. Still, they should expand the window that we can see the script in at the very least. 14 lines is pathetically small.
It's especially absurd considering there was no limitation on the prior version. Thanks for your input, happy to hear I'm not the only one dealing with this madness.
@kavila This is a PI that showed up (again) in 10.36:
PI-109809: In Jamf Pro 10.36.0, the Script window only displays 14 lines.
Jamf Support advises: “Currently there is no workaround for this.”
Almost a year today Jamf Pro 10.28 did the same thing. whaaa
https://community.jamf.com/t5/jamf-pro/script-window-10-28/m-p/233532
This is unfortunately not uncommon with Jamf Pro releases. Jamf seems to have some issue with bug regression in their development process. I did recall this was a problem on some older release, but couldn't remember specifically which one, so thanks for pointing this out. Hopefully they can address this soon.
Jamf has also removed(?) most of the script themes and syntax highlighting has disappeared. Very bad regression.
Noticed that as well. Baffling.
Yeah, I'm seeing that in the most recent release. Good grief. Why would they remove those features? What did they ever do to anyone?
here, too. we are running 10.36.0. It's not a bug, it's a feature :-D
this behavior should be fixed in the last update, but it is not.
If you are changing the cut-off options for the finalization when building factory toolkit, copy the cutoff.json.default to your board overlay into file path chromeos-base/factory-board/files/py/config/cutoff.json. Change values in the config file, and rebuild a new factory toolkit. This config file also applies to reset shim.
My Balance Now
Really frustrated to see this return 🤦🏻‍
