SecureToken for Admin Accounts
  • August 6, 2018
  • 37 replies
  • 528 views
Show first post
  • November 22, 2023
@johntgeck I just tried your script and got the same error.
Then ran my iteration here and it does work.. just prompts for an additional pop up from sysadminctl
#!/bin/bash #get logged in user currentuser=$(/bin/ls -la /dev/console | /usr/bin/cut -d ' ' -f 4) user_entry="" #prompt user for their password while [ "$user_entry" = "" ] ; do user_entry=$(osascript -e ' tell application "Finder" activate try display dialog "Please enter local password" with title "Assign SecureToken" default answer "" set user_entry to the (text returned of the result) on error number -128 set user_entry to "" end try return user_entry end tell') done echo $user_entry #pass info into terminal to grant token from admin user sudo /usr/sbin/sysadminctl -secureTokenOn $currentuser -password $user_entry interactive || -adminUser $4 -adminPassword $5 exit 0
Thank you for this!
This worked for me.
I created another user (admin1) and when I created that user, it had SecureToken Enabled.
I logged into the original Admin account that didn't have it enabled and ran this script from Terminal.
From there, I typed in the password for original admin account, and when the box came up for credentials, I used the newly created admin1 credentials. It enabled SecureToken for my original admin and then I deleted the other admin account that I created.
Saved me the trouble of having to wipe/re-install OS.
  • December 14, 2023
Thank you for this!
This worked for me.
Yep, this is the solution we've been using in limited scope, but it doesn't help the other 200 or so computers that have been deployed that are in a similar situation. I'm not walking around and touching them all.
  • December 14, 2023
I have managed to get this pretty streamlined where all the user has to do is setup a quick 5 minute zoom meeting, then run a policy from Self Service, and then once it asks to change system settings, we get take control of the screen and enter the IT admin account.
Then they are now secure token enabled and good to go.
Glad to share more if you want to know more.
  • December 14, 2023
We have been able to resolve about 150 of these issues will minimal effort so our users can now update on their own and don't have the secure token issues.
  • December 14, 2023
My problem is most of the computers suffering this issue are unattended (lab or classroom computers), but I'm taking all of these suggestions to heart to find the most streamlined solution.
  • December 14, 2023
do they all have the same admin account password?
  • December 14, 2023
They do, yes.
  • September 17, 2024
my problem is laps totally screwed this up.  Our original admin password doesnt always work for this, where yes it recognizes the admin password as correct and shows the admin with the token and volume ownership, but its not working to allow an update (almost like laps broke the actual record of the admin password for volume ownership).  So im not sure how to proceed since I cant get any of the above methods to work.  Only one I didnt try was to create another admin user and see if it gets a token.
  • September 18, 2024
The jamf documentation outlines that it changes the password but doesnt change the cryptographic encryption password. So expected behaviour and it will vary from machine to machine based on other variables...
Its a bit of a dogs breakfast to get consistant across a fleet of macs...
Which is why, despite the obvious security advantages of LAPS, we still maintain a separate local admin that does not have a rotating password.
We use the LAPS password in the event that a user needs to perform an unexpected admin task in the field.
So I have come up with a script to change the laps passwords on a specified smart group back manually to a specific password.  This is helping us undo some of the issues we have seen on Apple Silicon with volume ownership.  Obviously for security reasons I would run this only locally on a machine and not upload this script to the jamf cloud distribution point without some encryption of passwords.
#!/bin/bash # API USER user="YOUR_API_USERNAME_HERE" # API PASSWORD pass="YOUR_API_USER_PASSWORD_HERE" # URL (https://yourjamfserver.jamfcloud.com) jurl="https://YOUR_JAMF_URL_HERE" # Smart group or static group ID to get computer IDs from groupID="YOUR_SMARTGROUP_ID_HERE" # Define the admin user name adminname="YOUR_ADMIN_USERNAME_HERE" # New LAPS password to set newPassword="YOUR_PASSWORD_HERE" # Get Bearer token for API calls getBearerToken() { response=$(curl -s -u "$user:$pass" "$jurl/api/v1/auth/token" -X POST) token=$(echo "$response" | plutil -extract token raw -) tokenExpiration=$(echo "$response" | plutil -extract expires raw - | awk -F . '{print $1}') tokenExpirationEpoch=$(date -j -f "%Y-%m-%dT%T" "$tokenExpiration" +"%s") echo "Token acquired." } # Invalidate the token once done invalidateToken() { curl -w "%{http_code}" -H "Authorization: Bearer $token" "$jurl/api/v1/auth/invalidate-token" -X POST -s -o /dev/null echo "Token invalidated." } # Check token expiration and get a new one if necessary checkTokenExpiration() { nowEpochUTC=$(date -j -f "%Y-%m-%dT%T" "$(date -u +"%Y-%m-%dT%T")" +"%s") if [[ tokenExpirationEpoch -gt nowEpochUTC ]]; then echo "Token is valid." else echo "Token expired, fetching new token." getBearerToken fi } # Run the function to get the token getBearerToken # Grab all computer IDs from the smart group (ID 802) echo "Fetching computer IDs from group ID: $groupID" computerids=($(curl -s $jurl/JSSResource/computergroups/id/$groupID \\ -H 'accept: application/xml' \\ -H "Authorization: Bearer $token" | xmllint --xpath '/computer_group/computers/computer/id/text()' -)) echo "Found Computer IDs: ${computerids[@]}" # Loop through all computer IDs to look up the managementId and reset the LAPS password for id in "${computerids[@]}"; do checkTokenExpiration # Get computer details to retrieve the managementId computerInfo=$(curl -s "$jurl/api/v1/computers-inventory/$id?section=GENERAL" \\ -H 'accept: application/json' \\ -H "Authorization: Bearer $token") # Extract the managementId using jq managementId=$(echo "$computerInfo" | jq -r '.general.managementId') if [[ -z "$managementId" || "$managementId" == "null" ]]; then echo "No management ID found for computer $id, skipping..." continue fi echo "Found Management ID: $managementId for computer $id" # Reset the LAPS password for the macadmin user using the correct API endpoint curl -s -X PUT "$jurl/api/v2/local-admin-password/$managementId/set-password" \\ -H "accept: application/json" \\ -H "Authorization: Bearer $token" \\ -H "Content-Type: application/json" \\ -d "{\\"lapsUserPasswordList\\": [{\\"username\\": \\"$adminname\\", \\"password\\": \\"$newPassword\\"}]}" || echo "Failed to reset LAPS password for computer $id with Management ID: $managementId" done # Invalidate the token when done invalidateToken exit 0
  • December 13, 2024
They do, yes.
Then theoretically (unfortunate security risk) you could embed the admin password into the script and sent the whole script to the Mac to grant the secure token access. You would still need to be at the Mac though to enter in the user credentials.
It is a pretty unfortunate situation. Have yet to find a fully automated solution, but this is the best I have come up with thus far.
#!/bin/bash #get logged in user currentuser=$(/bin/ls -la /dev/console | /usr/bin/cut -d ' ' -f 4) #sudo jamf policy -id ## sudo killall opendirectoryd user_entry="" #prompt user for their password user_entry=$(/usr/bin/osascript<<END application "System Events" activate set the answer to text returned of (display dialog "Please Enter your Password:" with title "Assign Secure Token" default answer "" with hidden answer buttons {"Continue"} default button 1) END ) #pass info into terminal to grant token from it Admin user sudo -u $4 /usr/sbin/sysadminctl -secureTokenOn $currentuser -password $user_entry interactive || -adminUser $4 -adminPassword - tokenstatus= /usr/sbin/sysadminctl -secureTokenStatus $currentuser echo $tokenstatus exit 0
Hope this helps.
