Is anyone using the Casper Self-Help feature to enable Helpdesk staff the ability to "give" software to a user? The software would be packaged by a group that handles packaging. The Helpdesk would need be able to queue up the package so the user can select it, and it installs without prompting for admin rights. I would imagine the process would prompt the user to log off, then the install would happen, followed by a reboot.
Thanks,
Don
