Send mobile device command to mobile device smart group
  • March 21, 2019
  • 28 views
Hello!
I need to send the update inventory command to my iPads to be able to check when they run out of battery.
Gladly i succeeded writing the test script to send it to one device, but i im looking for a way to send it to a whole group instead of doing it device per device.
This is the beautiful script.
deviceID="59"
# This works for single commands
data="<mobile_device_command><general><command>UpdateInventory</command></general><mobile_devices><mobile_device><id>59</id></mobile_device></mobile_devices></mobile_device_command>"
curl -fsku "${usr}:${pass}" -H "Content-Type: text/xml" "${jssdomain}/JSSResource/mobiledevicecommands/command" -d $data -X POST
Do you have any idea of how would it work for mobile devices smart groups?
Regards!
  • May 9, 2019
I'll bump this since I actually have the same question.
Forum|alt.badge.img+20
  • Employee
  • May 9, 2019
To send this to multiple devices, you would just add additional instances of the mobile device ID to the existing XML array. For example:
    <general>
    </general>
    <mobile_devices>
        <mobile_device>
            <id>59</id>
        </mobile_device>
        <mobile_device>
            <id>60</id>
        </mobile_device>
    </mobile_devices>
  • April 14, 2020
@jose.gutierrez @evan684
Had the same problem and thought this might help you guys out
jamfProURL="https://jamf.jamfcloud.com"
jamfUser="jamf.admin"
jamfPass="jamf1234"
mobileDeviceGroupID="69"
mobileDeviceCommand="SettingsEnableDataRoaming"
# Mobile Device Commands:    #
# UpdateInventory            #
# BlankPush                  #
# SettingsEnableDataRoaming  #
# Full list:                 #
# https://developer.jamf.com #
deviceIDs=( $( curl -s -u "$jamfUser":"$jamfPass" $jamfProURL/JSSResource/mobiledevicegroups/id/$mobileDeviceGroupID -H "Accept: application/xml" -X GET | xpath "//mobile_device_group/mobile_devices" | /usr/bin/perl -lne 'BEGIN{undef $/} while (/<id>(.*?)</id>/sg){print $1}' ) )
for i in ${deviceIDs[@]}; do
    echo "Sending $mobileDeviceCommand to Device ID: $i..."
    /usr/bin/curl -sk -u "$jamfUser":"$jamfPass" -H "Content-Type: text/xml" -d "<?xml version="1.0" encoding="ISO-8859-1"?><mobile_device_command><general><command>$mobileDeviceCommand</command>></general><mobile_devices><mobile_device><id>$i</id></mobile_device></mobile_devices></mobile_device_command>" $jamfProURL/JSSResource/mobiledevicecommands/command/$mobileDeviceCommand -X POST > /dev/null
    if [[ "$?" == "0" ]]; then
        echo "   $mobileDeviceCommand Command Processed Successfully"
        echo "   $mobileDeviceCommand Error Processing Command"
    echo ""
done
