Hi all,
We are working on a way to disable the internal speakers of any device and make sure that they can only use headphones to listen to any audio coming out of the computer.
We are using Soundflower as a work around and it's working like a charm, but we are trying to find the .plist or terminal command that can set the default output device order for the system, so we can make sure that when a user plugs the headphones, they are activated by default, as soon as they unplug it, sound flower is selected as second option, and audio is deactivated.
We know there's a plist because if we change it manually it keeps the configuration, but we are unable to find it to manage it via CASPER.
Any clue or recommendation?
Thank you guys!!
Set headphones as default audio output
