Set Home Page for MS Edge using a Configuration Profile
  • November 21, 2023
  • 5 replies
  • 332 views
Is there a script to set up the home page for Microsoft Edge ?
Best answer by Nicholaus
This would be accomplished through a configuration profile. Here is an example of what I use to set the default homepage and new tab page in Edge. This is a configuration profile with the Application & Custom Settings configured:
Preference Domain: com.microsoft.Edge
Property List:
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>HomepageIsNewTabPage</key> <false/> <key>HomepageLocation</key> <string>https://yourhomepagehere.com</string> <key>NewTabPageLocation</key> <string>https://yournewtabpagehere.com</string> </dict> </plist>
Forum|alt.badge.img+20
  • November 21, 2023
 I would recommend using a Configuration Profile instead of trying to script it? The only reason to use a script is if you want to allow the user to change the setting later.
See this document on how to use Jamf's Custom Application payload to configure Edge.
https://learn.microsoft.com/en-us/deployedge/configure-microsoft-edge-on-mac-jamf
  • November 21, 2023
Property List:
donmontalvo
Forum|alt.badge.img+36
Pretty extensive list of key/value pairs...
Startup, home page and new tab page
  • June 18, 2024
Is there a script to set up the home page for Microsoft Edge using configuration profile?
Thanks
  • June 20, 2024
Found it.
Thanks
