Dear All,
I was wondering if anyone could help with this. I have modified the webproxy script with the securewebproxy command but when I try to run it, I get a response of "command not found". If I run the command in a terminal screen of "networksetup -setsecurewebproxy Ethernet 192.168.43.171 8080" it works fine
This is the script I am using .... please help
# Copyright (c) 2010, JAMF Software, LLC. All rights reserved.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are met:
# Redistributions of source code must retain the above copyright
# notice, this list of conditions and the following disclaimer.
# Redistributions in binary form must reproduce the above copyright
# notice, this list of conditions and the following disclaimer in the
# documentation and/or other materials provided with the distribution.
# * Neither the name of the JAMF Software, LLC nor the
# names of its contributors may be used to endorse or promote products
# derived from this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY JAMF SOFTWARE, LLC "AS IS" AND ANY
# EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
# DISCLAIMED. IN NO EVENT SHALL JAMF SOFTWARE, LLC BE LIABLE FOR ANY
# DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
# (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
# LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
# ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
# SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# SUPPORT FOR THIS PROGRAM
# This program is distributed "as is" by JAMF Software, LLC's Resource Kit team. For more
# information or support for the Resource Kit, please utilize the following resources:
# http://list.jamfsoftware.com/mailman/listinfo/resourcekit
# http://www.jamfsoftware.com/support/resource-kit
# Please reference our SLA for information regarding support of this application:
# http://www.jamfsoftware.com/support/resource-kit-sla
# ABOUT THIS PROGRAM
# NAME
# setSecureWebProxy.sh -- Configure a web proxy for a specified network interface
# SYNOPSIS
# sudo setSecureWebProxy.sh
# sudo setSecureWebProxy.sh <mountPoint> <computerName> <currentUsername> <networkInterface>
# <proxyAddress> <port>
# If the $networkInterface parameter is specified (parameter 4), this is the Network Interface for
# which the search domains will be set. The expected values for the $networkInterface parameter can
# be found by running the command:
# networksetup -listallnetworkservices
# If the $proxyAddress parameter is specified (parameter 5), this is the proxy address that will
# be set.
# If the $port parameter is specified (parameter 6), this is the port to which the proxy traffic
# be passed.
# If no parameters are specified for parameters 4, 5 or 6, the hardcoded value in the script will be
# used.
# DESCRIPTION
# This script will configure the web proxy on the specified network interface.
# HISTORY
# Version: 1.1
# - Created by Nick Amundsen on July 11th, 2008
# - Modified by Nick Amundsen on August 5th, 2008
# DEFINE VARIABLES & READ IN PARAMETERS
# HARDCODED VALUES ARE SET HERE
networkInterface="Ethernet"
proxyAddress="192.168.43.171"
port="8080"
# CHECK TO SEE IF A VALUE WAS PASSED IN PARAMETER 4 AND, IF SO, ASSIGN TO "networkInterface"
if [ "$4" != "" ] && [ "$networkInterface" == "" ];then
networkInterface=$4
# CHECK TO SEE IF A VALUE WAS PASSED IN PARAMETER 5 AND, IF SO, ASSIGN TO "proxyAddress"
if [ "$5" != "" ] && [ "$proxyAddress" == "" ];then
proxyAddress=$5
# CHECK TO SEE IF A VALUE WAS PASSED IN PARAMETER 6 AND, IF SO, ASSIGN TO "port"
if [ "$6" != "" ] && [ "$port" == "" ];then
port=$6
# SCRIPT CONTENTS - DO NOT MODIFY BELOW THIS LINE
if [ "$networkInterface" == "" ]; then
echo "Error: No network interface has been specified."
exit 1
if [ "$proxyAddress" == "" ]; then
echo "Error: No proxy address has been specified."
exit 1
if [ "$port" == "" ]; then
echo "Error: No port was specified."
exit 1
OS=/usr/bin/defaults read /System/Library/CoreServices/SystemVersion ProductVersion | awk '{print substr($1,1,4)}'
if [[ "$OS" < "10.5" ]]; then
echo "Setting web proxy for OS $OS..."
/System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Support/networksetup -setsecurewebproxy "$networkInterface" "$proxyAddress" "$port"
/usr/sbin/networksetup -setsecurewebproxy "$networkInterface" "$proxyAddress" "$port"
