Setting Default Browser to Edge MacOS
  • June 14, 2021
  • 27 views
HealthcareMac
New to Jamf Pro,
Is it possible to control the default browser settings via Jamf Pro? we are working on SSO for edge and wanted to set the default as Edge browser without the endpoint having to go in and set that up. (even though its only 3 steps to change it)
1 reply
samuelbaiden
  • August 11, 2021
Try and have a look at this from Github. You may need to add the bundle Id for Edge and uncomment that line in the script. Note I have not tested this of late so I can't tell if it is still working.
https://github.com/aysiu/Mac-Scripts-and-Profiles/blob/main/ChromeDefaultBrowser.sh
