Setting Desktop Background for All Users with Configuration Profiles
  • August 13, 2015
  • 18 replies
  • 133 views
I am attempting to set a custom desktop background for all users through Configuration Profiles, and it is working. However, it is locking the desktop backgrounds, and I am unable to change it once it is set. There is an option in the Configuration Profile to lock the desktop background, and I do not have it selected, but it seems to be locking it anyway. Users need to be able to change the background after it is set.
I am deploying the background image into a folder in the root directory, and simply setting the background to it using a configuration profile. Is there a better way to do this? Any ideas on why it is locked, when that option isn't selected? The only way I've been able to change the desktop background is to remove the configuration profile from the computer, then reimage it completely.
Best answer by andrew_nicholas
I went the non-profile method and just created a custom package that drops our background into /Library/Desktop Pictures and use a post install script to update ownership and replace the DefaultDesktop.jpg link in CoreServices. This makes it the same for all users but still lets them change it if they want.
Script for Reference:
chown root:wheel /Library/Desktop Pictures/Your_Wallpaper.jpg
ln -fs /Library/Desktop Pictures/YourWallPaper.jpg /System/Library/CoreServices/DefaultDesktop.jpg
djwojo
  • August 13, 2015
I have been using a package to deploy the background picture same as you, then using this modified python script to set it, due to the same lock out you brought up.
Graham Gilbert GitHub
So far, so good, but the lockouts need to be fixed in config profiles. Just because we set a feature, doesn't mean we should lock the rest!
  • August 13, 2015
RobertHammen
Forum|alt.badge.img+29
  • August 13, 2015
Configuration Profiles: Like MCX, but different. There's no "Once" functionality (or Often), it's all-or-nothing. So yeah, in this case, a script is the best approach.
  • August 13, 2015
You can get "Once" functionality if you use Tim Sutton's mcxToProfile tool and use the right flags. I was not previously aware of this and also thought that Profiles meant it was all or nothing. But Tim doesn't recommend doing the Often setting for Config Profiles because they give you very inconsistent behavior.
  • August 13, 2015
We do what @andrew.nicholas does - rather than using MCX or Config Profiles, we just replace DefaultDesktop.jpg with our own image. The added bonus is you get that as the "blurry" background for the login screen as well. So if you have a large logo, or widely used main color, the login screen will be recognizable.
georgecm12
  • August 13, 2015
I, too, finally gave up on trying to set the desktop picture via script, and I'm now just replacing the symlink to DefaultDesktop.jpg.
(For good measure, I'm also replacing /Library/Caches/com.apple.desktop.admin.png and setting it read-only, so that it always uses the same image.)
  • August 13, 2015
Yep,
I think if you want to change it pragmatically you might have to use python and Apple APIs... I gave up too and just have Casper install the new image with the same name over the old one. ( I did it for X.9 so not 100% sure)
C
apizz
Forum|alt.badge.img+15
  • August 15, 2015
bentoms
Forum|alt.badge.img+35
  • August 15, 2015
If only this FR was implemented already.
  • August 17, 2015
@andrew.nicholas That seems to work just as I was hoping! Really wish the Configuration Profile worked for this, though. Using Composer to monitor system file changes, I was able to capture this as a package with the background image itself and implement it into my imaging.
  • August 17, 2015
@sforney Glad to hear it!
  • November 3, 2015
Does anyone have this script working for El Capitan? We get "operation not permitted" errors on the second line (even when running manually via terminal).
  • November 10, 2015
@Yager
In El Capitan it becomes slightly more complicated but it just involves changing the name of the file being pointed to.
osVers=$(sw_vers -productVersion | awk -F. '{print $2}')
picLoc="/path/to/picture"
#For El Capitan update the default wallpaper by replacing file the symlink points to
#For everything else, just replace the symlink
#Replace the Default Picture
if [[ $osVers == 11 ]]; then
    mv /Library/Desktop Pictures/El Capitan.jpg /Library/Desktop Pictures/El Capitan.bak.jpg
    mv "$picLoc" /Library/Desktop Pictures/El Capitan.jpg
elif [[ $osVers -lt 10 ]]; then
    #Replace the Default Desktop Link
    ln -fs "$picLoc" /System/Library/CoreServices/DefaultDesktop.jpg
-Andrew
emily
  • November 10, 2015
I think I built out or Desktop Background setup using Composer. I just want it there day one; I don't want to force people to always use it (though some do!).
  • November 10, 2015
One note about Andrew's script - if you run it more than once on a computer, you may wipe out the .bak copy and replace it with $picLoc.
To avoid, use something like this for the 10.11 portion...
if [[ ${osVers} -eq 11 ]]; then
  if [ ! -f /Library/Desktop Pictures/El Capitan.bak.jpg ];then
    echo "Coping /Library/Desktop Pictures/El Capitan.jpg as El Capitan.bak.jpg"
    echo "/Library/Desktop Pictures/El Capitan.bak.jpg already exists"
  ln -sf "$picLoc" /Library/Desktop Pictures/El Capitan.jpg
  • March 28, 2018
I like the solution you provided andrew.nicholas , but SIP is preventing me to change the link on CoreServices.
ln -fs /Library/Desktop Pictures/YourWallPaper.jpg /System/Library/CoreServices/DefaultDesktop.jpg will show a 'operation not permitted' when running manually and I suppose the same reason it won't run in our deployment.
Am I missing a step on this? Any help is appreciated. Thanks!
@sidneimoreira the link method won't work from 10.11 on, so a simple solution is to just alter the default file called. The post is dated, but you should really just need to alter it by adding cases for 10.12/10.13/etc...
  • May 31, 2019
how can I undo the command
in macOS High Sierra and El Capitan?
just updated the devices possible to an higher OS and trashed those not update-able! :)
