Working my way through setting up a Clustered JSS environment. My Main JSS is on our internal VPN running Ubuntu and connected to our consolidated MySQL Server. I have tested, JSS is accessing the database and everything is functioning properly.
Now, I am building an external instance of the Web Server running Ubuntu as well. I have run apt-get update, installed Java, and MySQL Server. I Stopped here. I am stuck. Should I create another jamfsoftware database and user on this external instance then run the linux installer for the JSS. Afterwards, access the External JSS and enable clustering. I intend to Cluster this to the internal JSS and also make it limited access. Where should the Load balancer sit. I am hoping someone has completed a similar setup before. My network folks are not much help here.
