Shell scripting bat signal: defaults not obeying variable resolution
  • June 27, 2012
  • 27 replies
  • 106 views
Show first post
Forum|alt.badge.img+31
  • June 27, 2012
My first thought was MCX as well, but I didn't have time to test it out. I do vaguely remember something in WGM that allowed you to do this, I think. Been a while since I had to use OD to Manage Macs so I am starting to forget some of it.
-Tom
  • June 27, 2012
I originally tried MCX to plant the volume there, but due to every login essentially being an offline login with FV2, it didn't quite work the way I expected and you'd get an error that the system couldn't connect to the server. The script was really just an easy way for techs to setup a "drive map." More a stop-gap solution than anything else.
