Simple Bash script
  • February 23, 2024
  • 5 replies
  • 63 views
I have a configuration profile that adds our VPN configuration. I then have a policy that kicks off this simple bash script.
open “/System/Library/CoreServices/Menu Extras/vpn.menu”
All this does is check the box for "Show VPN status in the menu bar"
This is the error that I'm getting.
Script result: The files /“/System/Library/CoreServices/Menu and /Extras/vpn.menu” do not exist.
When I run the command in the terminal it completes successfully.
Best answer by sdagley
Did you really use “ (curly double quotes) instead of " (straight double quotes)? If so change them all to straight quotes.
AJPinto
  • February 23, 2024
On my device I can't even run that command in terminal, I get "The files /Users/UserID/“/System/Library/CoreServices/Menu and /Users/UserID/Extras/vpn.menu” do not exist." I believe core services is a symbolic link directory, you will need to locate the original path.
lrwxr-xr-x   1 root  wheel       90 Feb  2 11:19 coreservicesd -> ../Frameworks/CoreServices.framework/Frameworks/CarbonCore.framework/Support/coreservicesd
sdagley
  • February 23, 2024
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • February 23, 2024
I think the problem is that you're trying to run something by command line that opens an app. Jamf Pro runs commands as root, which means you're trying to open the app as root. But root isn't logged in.
Add a couple lines to the beginning to get the current user. Then use sudo or su to run the open command as that user.
  • February 23, 2024
That was it. Thank you.
howie_isaacks
Forum|alt.badge.img+23
  • February 23, 2024
I write all of my scripts in BBEdit and sometimes in CodeRunner. I actually never gave this any thought... curly vs. straight quotes. I figured the style of the quotes was controlled by the font they're typed in.
