Smart Mobile Device Group - Export of CSV Mobile Device yields 0 results
  • March 12, 2019
  • 30 views
Posting this here so others are aware.
While displaying a Smart Mobile Device Group. If you attempt to export a CSV selecting "Mobile Device" you will always get a .csv of 0 bytes. I confirmed this with support.
Only workaround: Export as "Mobile Device Group Memberships" it will give you multiple duplicate results but you should be able to filter to use excels duplicate removal feature to filter them down.
I hope they fix this soon.
Forum|alt.badge.img+19
  • March 12, 2019
Which version of Jamf Pro are you on? I feel like this was broken at one point and now fixed in later versions.
  • March 12, 2019
I also found this discussion where something similar looks like it was happening about a year ago but for the computer side of Inventory.
It looks like it was resolved in 10.9
https://www.jamf.com/jamf-nation/discussions/24564/export-of-populated-smart-group-is-empty
  • March 12, 2019
Ryan.ball - Running version 10.10.1-t1551187745
Support did confirm it is an issue in the current build.
